<~----> Best air flow - Hardware Canucks
Old February 9, 2013, 03:26 AM
The Quicken's Avatar
Default Best air flow
I'm looking for some input on best air flow for my case, I have an Antec 302, no GPU but full HDD bays.
Pic below is same case I have.
Fans marked Red #'s are self explanatory, Blue #'s represent fans on side/s of case. #6 is behind CPU.
Which would be best exhaust/intake ?
Old February 9, 2013, 05:38 AM
you can really do whatever you want.... I have my case setup so that ive got 2 intake fans on the front (1 &2) pulling air through my rad, blowing onto the GPU, and exhausting out 4 & 3 (a 120mm on 4 and 2x 140mm on 3)
If you wanted for dust, you could make all fans push air out of the case, and make the #4 draw air in, since its high up, but dont makee#3 intake, as dust would settle and menace you forever lol.
It also depends if you are using an ALC or not....If you are using an air cooler, this is the best setup IMHO, the picture above.
If youve got an ALC, or custom loop, you dont need much air blowing over the top of things, so dont worry too much
Bought Items:
GTX 470 from ZeroFlux
Swiftech MCW60 from chubaka
Sold Items:
Steelseries Siberia V2 to MAK
Zalman Fan Controller, OCZ Mem Fan Funguseater
Current system:
i5 2500k @ 5 Ghz
Zotac gtx 470
8GB Corsair Dominator ram @ 1333
Old February 9, 2013, 05:56 AM
1256 intake 3 and 4 out.
Positive pressure is better for dust so have better intake than exhaust.
If your pushing more cooler air in the exhaust fans will remove it easily and any excess that isn't removed by the exhaust fans will get out any gaps in the case rather than negative pressure when it comes in the gaps(attracting dust to where there are no filters).
Also think about getting a second fan for the AIO cpu cooler, not only will it help keep the cpu cooler but should improve the amount of air getting out of the case.
Old February 9, 2013, 06:52 AM
I would block 5 and 6 with some black cardboard so you can't notice it, 1 and 2 intake, 3 and 4 exhaust (that is what I did with my antec 300 even with a gpu and everything still runs nice and cool...the box my 300 came in was where I grabbed the piece of cardboard to block). This will be the smoothest airflow. Air goes in low at the front and out high at the back (hot air naturally rises). I know some people like to jam a fan where ever there is a spot, but it creates disturbed airflow and therefore potential hotspots and also extra noise. IMO the only reason to use 6 is if you are concerned with a hot running motherboard, and the only reason to use 6 is if you have a hot running graphics card. This setup also forces all air in through the front which has a dust filter, so you have nice clean air in your case.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old February 9, 2013, 03:28 PM
Point taken on #6, I forgot to include my heatsink in pic.
Old February 9, 2013, 03:34 PM
]1256 intake 3 and 4 out.
This makes sense to me (except for 6 - #6 'bugs me.)
My Coolmaster Hyper 212 intake is fan is on the right, pushing air through the rad out to #3 & #4.
I've got to open it up tonight to add a molex/sata power adapter, maybe I'll take a pic of what really going on. (Wires/HDDs etc)
Old February 9, 2013, 05:25 PM
Thats only if you want to put fans in / have fans for each spot..
BTW, if you have 4 intake and want a third exhaust you could flip the PSU, it'll be fed plenty of cool air from 1,2+5 and will mean you have less cleaning to do
(especially if the filter isn't easily removed)
Old February 9, 2013, 11:05 PM
Arrows represent current air flow.
Old February 10, 2013, 01:53 AM
Tidy up the cabling (get it all behind the motherboard tray) and your good... there is plenty of airflow in that case as is... if anything you could remove fans so it's quieter.
Old February 10, 2013, 04:17 AM
Your good for fans. As mentioned you should tidy up cabling to improve flow. Get the excess cable behing the mother board tray or hard drive cage.
Flow is too low with two pumps. Mnemonicman Water Cooling 49 December 29, 2012 05:46 PM
enough flow for my loop snef Water Cooling 6 July 4, 2012 08:14 PM
Flow sensor clshades Water Cooling 2 March 27, 2012 07:24 PM
Flow Rate? MattC Water Cooling 7 August 10, 2011 10:24 PM
Case with best air flow? Quirck Cases 7 May 23, 2011 08:30 PM
