<~----> Quiet 120mm fans? - Page 2 - Hardware Canucks
Old January 6, 2013, 03:19 PM
How big of an effect does airflow have on cpu temps with the antec 620 Kuhler?
Old January 9, 2013, 11:44 AM
Silent Wings 2 fans from be quiet,the best after noctua!!!!
Old January 9, 2013, 02:39 PM
bigFOIG's Avatar
Gentle typhoons in my opinion. There's no noise emitted from the fan itself, as in no annoying humming or buzzing from the motor. If you hear anything, it's just an whisper quiet airy sound. And if you want even quieter, they're great for undervolting.
Old January 9, 2013, 11:18 PM
Rollergold's Avatar
I'm giving the Vote to the Gentle Typhoons. great static pressure, great air flow, very quiet. The Noctua's are a close second but the color scheme isn't for everyone.
Asus P6X58-E WS | i7 920 D0 @ 4.01ghz W/ Apogee HD Block | 24gb (3x 8gb) Corsair Vengeance 1600 | 2x EVGA GTX 680 SC's in SLI W/ XSPC Razor Blocks |
4x 1tb WD Black Drives | SB Recon 3D PCIe | Swiftech MP655-SE Pump | Swiftech Maelstrom Res | CM HAF 932 | Corsair HX 850 (3 yr's old) | Asus VH236H + PA238QR
Old January 10, 2013, 11:44 PM
GT7R's Avatar
Gentle Typhoon gets my personal vote as well.
Old January 11, 2013, 10:42 AM
tangrisser's Avatar
Does the pressure matter? I've seen some companies promoting their fans creating static air pressure (particularly Noctua.)
Is this something that would help cool things better without being louder? I'm thinking concentrated air pressure forced directly into the radiator like Antec Kuhler should help it cool better. Or am I just a big sucker for marketing terms?
Check out my SALE page
Old January 11, 2013, 02:26 PM
^^^static pressure will allow higher air flow through something that is resisting the flow (like a radiator, or air cooler with tightly packed fins). If it is pretty much unrestricted flow static pressure is less of a factor.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old January 11, 2013, 05:41 PM
dustin1706's Avatar
I'm a big quiet freak and I've tried tons of fans. My current favourites are the noctua F12s. Followed by the Gentle Typhoons (AP-12 or AP-13). Fractal SSR2s aren't bad either.
I run the F12's at 500 RPM. I have an OC 3930 and mobo on a 3x120 and an oc 680 on a 2x120. @20* ambient I see 22/24 idle, and after 1 hour 100% load via prime 95 and furmark I see 55/52. So they definitely put out enough air for me even at 500 RPM.
Rig1 in "My System Specs"
Rig2: Q6600, P5DN-D, GTX650, 4GB HyperX, LG BD drive, TT armor case, ek supreme HF, 655 pump, XP
Dell XPS17 - i7 2820QM, 8GB ram, 1920x1080, BluRay, GT555m 3GB, 240gb Neutron GTX, 640GB Seagate, Win7 64
Server - i5 3450, Asus P8Z77-I Deluxe, 4GB DDR3, LSI MegaRAID 9240-8I, OCZ Vertex 4 120GB, 2x SG Barracuda 3TB(RAID1), 2x WD green 2TB(RAID1), Fractal Design Array R2, WHS 2011
  #19 (permalink)
Old January 21, 2013, 09:02 PM
cougar vortex 120 mm pwm fans are great, currently having 2 p/p for my water 2.0 pro. inaudible in fractal design r4. you can probably find them around $13 ish each pm'ed, or old school thermalright ty series are good too but they are 140mm but with 120 mm mounting holes, had them in silver arrow near silence as well
  #20 (permalink)
Old January 22, 2013, 09:20 AM
Soultribunal's Avatar
Static Pressure is the force the fan applies to the air movement itself. With high pressure densely packed HS's and Rads will see better performance vs fans with little static pressure.
-ST
[FS] GTX560Ti 448, 120mm radiator, 120mm/200mm fans... WTB/T: Modular PSU, i5 2500k bundle wonton1017 Buy/Sell & Trade 2 June 18, 2012 05:13 PM
Quiet 120mm fans Caldezar Air Cooling 9 October 19, 2010 03:47 PM
GELID Silent 12 1000RPM 120MM Quiet Fan cul8erppl Air Cooling 9 September 4, 2010 06:26 PM
Looking for QUIET 120mm fans Caldezar Air Cooling 20 July 20, 2010 01:32 PM
Good quiet 120mm watercooling Realityshift Air Cooling 14 March 5, 2010 07:19 AM
