Old December 6, 2012, 08:24 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default Spire Introduces X2 Branded Nano-Tech Fan Series
Utilizing a special nano-particle lubricant, the new X2 Nano-Tech fans offer an exponentially longer lifteime than standard fans.
Typical oil seal bearings in fans wear down easily due to the constant friction, and therefore have a fairly short lifetime. Advertised as having a 70,000 hour lifetime, the X2 Nano-Tech fans are made using smaller ball bearings resulting in a considerably quieter fan, and allowing the fan blades to be much larger, increasing airflow.
Read more here: Spire Introduces X2 Branded Nano-Tech Fan Series | Hardware Canucks
Spire Introduces the TME III CPU Cooler Sam_Reynolds Press Releases & Tech News 3 February 23, 2012 09:06 AM
Spire Announces the BlackDragon Series Power Supplies Sam_Reynolds Press Releases & Tech News 2 January 20, 2012 02:04 PM
Spire Announces Kepler Series Universal CPU Coolers Sam_Reynolds Press Releases & Tech News 0 October 10, 2011 10:11 AM
Spire Introduces the Swirl Cylinder Towering CPU Cooler Sam_Reynolds Press Releases & Tech News 13 June 4, 2011 11:42 AM
VIA Introduces New VIA Nano 3000 Series Processors FiXT Press Releases & Tech News 7 November 3, 2009 06:37 PM
