Old December 5, 2012, 01:30 PM
Default Need recommendation and question
Currently looking to do a Fortress FT03-Mini build and I want to swap out the stock fan for a PWM fan
can someone give me a recommenation? And is it easy to adjust fan setting in bios, or is there an instruction here on the forum? Fan size is 140mm and will have a Corsair H60 radiator in front of it.
Thanks
Old December 5, 2012, 01:49 PM
This is misleading, I thought you needed someone to recommend a question, I had some good ones too.
Why not use an external fan controller?
Old December 5, 2012, 02:33 PM
dandelioneater's Avatar
Are you talking about buying a 4 pin pwm fan and plugging it into the cpu fan header of the motheroaords to cool the H60 radiator? The motherboard should control the speed of the fan according to the temperature of the cpu. Any decent 1366, AM3 board should have fan control built into the bios. Usually you can adjust a fan to run at a certain rpm 24/7, or in newer boards, such as Asus Z77 boards and im sure other brands have this as well: the ability to control fans that are plugged into the motherboard with a certain profile, performance, balanced, quiet mode, etc. Some fans can be controlled with a user defined curve with something like ASUS's AI suite software.
^^ rambling on....haha
Recommendation(s) SupernovaIIX CPU's and Motherboards 2 November 23, 2011 06:54 PM
MMO recommendation? Duzey Gaming 27 March 2, 2011 12:01 PM
DDR3 question and recommendation apvm New Builds 10 October 7, 2009 09:23 AM
PSU recommendation? SugarJ Power Supplies 6 March 26, 2009 09:26 PM
LCD recommendation ElAguila Display Units 1 August 24, 2008 06:18 PM
