Originally Posted by summak hello canuckers
basically, I will start overclocking soon, i had did earlier but it was in stock fan and the temps were rising to around 60 degrees to 70 degrees during the stress test. sometimes it wud 80, so I thoought of coming back to normal mode until i get a new cooler.
Not looking for water coolers atm, so any air cooler out there to do the job??
I have, AMD AM3+ Phenom X2 560
Gigabyte 880ga ud3h
NZXT 210 Elite
And after doing a little research, I have found 2 contenders
Scythe Mugen 3 on Ebay
thank you |
I would say save up for something like this :
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819106011
your cpu OC'd probably cant even compare with an intel i3 or i5 stock. But if you really want to overclock it Im sure a hyper 212+ would cool sufficiently, and is alot cheaper, or kuhler620 which is 39.99 AR from ncix/memoryexpress
