Old November 14, 2012, 07:54 AM
Default Front fan is hot and back fan is fresh
Hey guys! Do you know if it's normal that the front fan is hot? sometimes the grid of my front 120mm fan is like 35c or 37c ,well i can put the hand on it but it's hot.
What is also strange is that the rear fan does not blow really hot air and the back grid is fresh, is that the same with our computers? because normally,the back fan blows hot air out of the case no? it blows warm-fresh air.
For my front fan ,i don't really feel airflow, of course it sucks air but i don't know why it's so hot.My temps are fresh tho,and the front fan is hot only in games.my GPU blows air towards the side (heatpipes) so that's strange...maybe drives??
Old November 14, 2012, 08:19 AM
"Quote This..."
I wasn't expecting this to occur until December 21st :)
Black belt in CAPS LOCK.
Old November 14, 2012, 08:31 AM
Sorry i don't catch it :X
EDIT:I understand now ....English jokes
Old November 14, 2012, 08:37 AM
"Quote This..."
2012 phenomenon - Wikipedia, the free encyclopedia
Old November 14, 2012, 08:42 AM
Any relation with air cooling? :X
Old November 14, 2012, 09:47 AM
odis172's Avatar
I would check the orientation of the fans to make sure they are blowing the proper direction. Also check the bios to make sure the rpm isn't turned way down manually or through bios rpm control.
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
Old November 14, 2012, 09:55 AM
CPUIDHW monitor :
FANIN0 = 19 rpm
FANIN1 = 757 RPM
FANIN3 = 1081 RPM
only 2x 120mm fans in the case right now.
i guess 757 is not a lot,gonna check the bios
Old November 14, 2012, 09:58 AM
Shadowmeph's Avatar
front fan on your case ? are you hard drives near that fan
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old November 14, 2012, 10:01 AM
Yes, one Seagate 1tb 7200rpm drive, quite close to it,i'd say, 5 centimeters between drive and fan
Old November 14, 2012, 10:29 AM
Soultribunal's Avatar
Originally Posted by bliz View Post
CPUIDHW monitor :
FANIN0 = 19 rpm
FANIN1 = 757 RPM
FANIN3 = 1081 RPM
If you have a fan grill that is hot, perhaps the motor is calling it quits? Espically with a 19RPM fan....that sounds like a whole different problem. Is your CPU fan plugged into you MB, because I bet you that is one of the readings there.
-ST
dual 5870 toxic cards, back to back overheating. dinmaster Video Cards 10 November 4, 2010 07:24 AM
L4D Fresh Zombies cmac79 Gaming 3 May 21, 2009 09:43 AM
Need some fresh input Supergrover Troubleshooting 1 October 23, 2008 07:30 PM
help with putting SP3 on a fresh WIN XP? bushwickbill O/S's, Drivers & General Software 2 August 2, 2008 11:26 AM
