Old November 14, 2012, 10:47 AM
Ok the 19 RPM is nothing, bios says 700rpm and 1080 rpm,i have 2 fans.So my front fan is 700 rpm,there is no adapter and i can't modify fan speed with the bios.I think the fan is made like that i won't push it. as long as the air in my computer is not hot...
Old November 14, 2012, 10:57 AM
Soultribunal's Avatar
Whats cooling your CPU? And What is that connected to?
-ST
Old November 14, 2012, 11:16 AM
Shadowmeph's Avatar
I am very sure that it is becasue of the heat from the hard drive ,
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old November 14, 2012, 11:19 AM
Actually,yes, it's warm between hard drive and fan, even Idle :)
Old November 14, 2012, 11:37 AM
if you open the case up and feel, is the front fan blowing air into the case?
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old November 14, 2012, 12:01 PM
Yeah.
Old November 14, 2012, 12:26 PM
Do you have software to tell you how hot your HDD's are getting?
Take a pic. Might be heat transferring from the Cage to Case.
So long as temps are in spec on the HDD. You're fine.
-ST
Old November 14, 2012, 01:43 PM
HDD is 25c idle. for the moment, stock intel cooler is cooling CPU but other coming.I don't know max HDD temps but mine look ok..
dual 5870 toxic cards, back to back overheating. dinmaster Video Cards 10 November 4, 2010 07:24 AM
L4D Fresh Zombies cmac79 Gaming 3 May 21, 2009 09:43 AM
Need some fresh input Supergrover Troubleshooting 1 October 23, 2008 07:30 PM
help with putting SP3 on a fresh WIN XP? bushwickbill O/S's, Drivers & General Software 2 August 2, 2008 11:26 AM
