Old September 16, 2012, 02:40 AM
Default Using Noctua Voltage-Adapters for Other Fans
My friend has a whole bunch of textra ULNA adapters from the Noctua fans he bought. I'm pretty sure I can use them with stock case fans, but I just wanted to confirm this.
Old September 16, 2012, 04:43 AM
Yep, you can do that.
Heatware
Old September 16, 2012, 10:27 AM
NyteOwl's Avatar
All they are is a resistor in series with the power lead to the fan. You may not get the exact same speed drop as you would with the Noctuas but they will work. I would be cautious about using them with a fan that has a significantly higher power draw that the Noctuas however due to the unknown power rating of the resistor they use.
Obsolescence is just a lack of imagination.
Old September 16, 2012, 12:07 PM
Will be fine, though some fans may not run on the lowest voltage one... I think 5v
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old September 16, 2012, 02:32 PM
alright, thanks for the headsup.
Replacing CM Evo fans with Noctua NFP12 Fans kr7777 Air Cooling 7 August 26, 2012 10:51 AM
Are noctua fans sufficient as a PSU fan? geoc Power Supplies 6 March 29, 2012 08:07 PM
[WTT] Noctua fans for your G34 cooler jtktam Buy/Sell & Trade 1 February 1, 2012 05:54 AM
Noctua Fans soulicro Air Cooling 13 April 16, 2010 09:34 AM
[WTB] Noctua NF-P12 Fans Chos3n Buy/Sell & Trade 9 April 22, 2009 02:40 AM
