Old August 16, 2012, 06:36 PM
Skyllz's Avatar
That Recon fan controller... POS...
I have one sitting here and i'm unable to make it work properly in 2 seperate system, their program wont connect or recognise it, tried all the stuff they mention in their tech support forums.
I would stick to conventionnal stand-alone controller, I am about to throw this one in the garbage to get a plain one with knobs again.
Is smoke supposed to come out of there?
Old August 16, 2012, 07:11 PM
Soultribunal's Avatar
There is also if you have a slot available:
Newegg.ca - Sunbeam PL-RS-PCI Rheosmart PCI 20W Fan Controller
Newegg.ca - SilenX IXA-FCEX External 4 Channel Fan Controller
-ST
Old August 16, 2012, 08:14 PM
Zer0's Avatar
Works fine for me. You're talking about the web service? There's only one problem I'm having, it doesn't recall saved settings for rpm's greater than 1300 from the webpage.
Old August 16, 2012, 08:23 PM
Shadowmeph's Avatar
Originally Posted by sswilson View Post
I found an older version of those in my tickle trunk the other day... works great!
I got mixed up and thought of the friendly giant lol
this reminds me to get off my but and grab some decent fans and a decent controller for both of my rads I never know which to get though
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old August 17, 2012, 05:53 AM
Skyllz's Avatar
In my case, it's on or off and the web service is a no go either. So it's not going anywhere for me.
Old August 17, 2012, 08:37 AM
Zer0's Avatar
I don't have enough info to help you with your issue. Not sure exactly what you mean by on or off, so you can't adjust the speed from the fan controller touch panel? You installed and ran the recon service as administrator right? You also plugged in the correct USB connector? There's two on the Recon, the one at the very end is a passthrough only, so you'll need to connect the middle one to your board.
Old August 18, 2012, 01:11 PM
Fudd Rucker's Avatar
Decided to go with the 4 channel external that soul linked earlier. Ill just keep it internal somewhere since once I get the right mix I won't need to change anything.
I couldnt think of something snarky or interesting to put here this time around.
Wii U Controller Arinoth Gaming 5 June 20, 2012 04:43 PM
Need a fan controller QuickDeath Air Cooling 10 February 10, 2012 02:53 PM
Which Fan Controller? Signal2Noise Air Cooling 24 August 24, 2009 11:34 PM
Which fan controller? donkon Air Cooling 7 May 16, 2009 05:22 AM
fan controller help Computergeek Troubleshooting 19 July 25, 2008 02:28 PM
