Old August 15, 2012, 10:41 AM
taimoorali007's Avatar
Default Which Case Fan and CPU Cooler?
Hi guyz,
Noctua NF-P12
NF-F12 PWM
Noctua NF-S12B FLX
Only these 3 are currently available in my area.
Which one do you guyz prefer as a case fans for best airflow in case?
Only these are option so plz suggest from these.
Thanks.
And which is the best overall in cooling?
CM Hypere 212 Evo
Noctua NH-U12P
Thanks
Old August 15, 2012, 02:49 PM
dandelioneater's Avatar
Noctua.at - sound-optimised premium components "Designed in Austria"!
I would use the S12B's for case ventilation and the the P12 PWM's for your cpu heatink as it has a 4 pin pwm connector and higher static pressure to force air through the fins.
For CPU heatsink selection I would go with the H212 as it is probably cheaper than the U12P, and performs just as well. But if aesthetics are a concern, then you might as well jsut go with all noctua fans and cooler. Noctua fans will be pretty quiet.
Old August 15, 2012, 03:05 PM
Ok, I'll buy Hyper 212 and Noctua P12 for Cooler, ryt? and S12B for case ventilation.
Old August 15, 2012, 03:45 PM
Yeah, I think that is the way to go. How much are those fans where you are? I think they are around 20 bucks a pop last time I checked here.
Old August 15, 2012, 04:14 PM
in usd, $15 for p12 pwn and $20 for s12b flx.
Old August 15, 2012, 04:48 PM
ZZLEE's Avatar
that's a nice price fore those. :)
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old August 15, 2012, 07:43 PM
rfglass's Avatar
I use these Newegg.ca - COUGAR CF-V12HP Vortex Hydro-Dynamic-Bearing (Fluid) 300,000 Hours 12CM Silent Cooling Fan with Pulse Width Modulation
Case Case Which Case!! response would be great. shogunsilly LinusTechTips Q&A 10 October 26, 2012 12:06 AM
A+ Case Black Pearl WCR Edition ATX Case Babrbarossa Reviews & Articles from the Web 0 June 19, 2007 09:28 AM
