Old April 14, 2008, 10:38 AM
CMetaphor's Avatar
Quadfather
Looks like i might be able to source 4x of them from domino on his FS thread, checking for all the details now! (Gottam make sure theyre the sleeve bearing ones tho. )
Old April 14, 2008, 01:57 PM
ebdoradz's Avatar
im only using Silverstoneteck fan,
i have only those in my both dfi rigs with armor case and they move alot of air, good air pressure, come with a fan controler, fan grill and all the mounting hardware
im using FM121 fan, (white one) and they are nice and quality fan. i wouldn't use them @ 12V because they move 110CFM and make noise but @ 7V or on the fan controler provide with them you cant beet it
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 5112mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
ABIT KT7A-RAID / AMD Athlon XP 1800+ @ stock/ 2*256mb PC133/ Geforce 4 mx440 / 250W PSU / Maxtor 20GB
Old April 14, 2008, 02:22 PM
MpG's Avatar
MpG MpG is offline
Hmm... I didn't think YL made anything but sleeve bearing fans. That aside, if you're mounting the fans horizontally, you might wish to avoid sleeve bearings, since there is a considerable amount of evidence pointing to a high-than-normal failure rate for them when mounted as such. (Incidentally, the Nexus fans are cherry-picked YLs, if you weren't aware.)
Personally, if you're serious about shutting the rig up, I'd take a hard look at Noctua's P-series fans. At all rpm's, I've found them noticeably superior to both the YL and the S-flex series. Using the included in-line resistors pulls them down to 900rpm, at which point I can barely hear them with my ear right next to them. I find the other fans usually need to be reduced by another 100-150 rpm before the same quietness is achieved.
Old April 14, 2008, 02:41 PM
Cptn Vortex's Avatar
Maybe I messed up. I thought the Sleeve bearings were Better for both horizontal and vertical mounting, but as you say, it is the Ball Bearings that are better? I'm confused...
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old April 14, 2008, 04:35 PM
MpG's Avatar
MpG MpG is offline
Sleeve bearings tend to be prone to unequal lubrication issues when mounted horizontally, whereas other types are more consistent, regardless of their mounting angle.
Old April 14, 2008, 05:31 PM
Interesting... Learn something new everyday!
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old April 14, 2008, 08:16 PM
MpG's Avatar
MpG MpG is offline
In all fairness, they're prone to lubrication issues. The evidence, while considerable, is largely anecdotal across forums everywhere. I've personally never seen a manufacturer admit to it. Some company out there probably has a sleeve bearing design that overcomes this issue. There are probably vast numbers of people who run them horizontally and have them last a million years so far. Just like we've all got a relative who smoked three packs a day and lived to be 120.
So this phenomenon is not absolute, but it's most definitely documented by this point, and avoiding them might save you a little grief.
