Old April 13, 2008, 03:13 PM
Default stock cooler problem
E6750 @ 2.66Ghz stock cooler
GIGABYTE p35 Ds3L
Mushkin em2 2x1 gb 5-5-5-18 ram
corsais vx450w psu
xfx geforce7600 256 mb
so ok here's the problem
the comp was build almost a month now
nothing happened until yesterday
when i boot up the machine, the stock fan went on and off. and the alarms start to go on when ever the fan stop spinning.
is the fan busted?
Old April 13, 2008, 03:17 PM
sswilson's Avatar
Sounds like it, unless there is something funny going on in your bios.
Make sure there's nothing blocking the fan blades (like a cable from something else) then go into bios and see if you can set the fan speed to 100% to verify that it's working.
Old April 13, 2008, 03:21 PM
Cardboard box with DSL's Avatar
I my older Gigabyte board did that when I first started it up, the fan would spin, then stop. I cant remember off the top of my head which setting it was, but it was just a random BIOS setting that I had to correct...
Try clearing the CMOS, and if you can access the BIOS, quickly disable the Q-fan control and that 'should' do it.
***Found it! Put your CPU fan header on one of the 3 pin ones (this is temporary, I just want your cpu to be cooled while you change the setting), the go into your BIOS and under PC Health Status, disable the CPU Smart FAN Control***
