Old July 11, 2012, 07:34 AM
Default HELP! Thinking of replacing stock fans for CoolerMaster Storm Enforcer case
i want to reduce noise level by replacing the cooler master enforcer case fans
I am after 120mm and 200mm fans.
what fans would you guys recommend?
Old July 11, 2012, 07:44 AM
stoanee's Avatar
If your case temps are good you can go for Noctua fans, they are very quiet but do not move a lot of air. If your case is too warm my choice would be Scythe Gentle Typhoon 1850 rpm fans. They move a lot of air with an acceptable noise ratio. These picks are for 120mm fans only.
heatware
Old July 11, 2012, 07:57 AM
thank you stoanee! i will def look into them :)!
Tags
cooler master , enforcer , fan , noise , storm
Silent case fans worth replacing? jiepo Air Cooling 7 June 27, 2012 11:28 AM
cm storm enforcer fans automaton Air Cooling 1 January 4, 2012 04:51 PM
Cooler Master CM Storm Enforcer Gaming Case Video Review Comment Thread SKYMTL Cases 11 April 19, 2011 10:53 AM
Replacing NH-D14 stock fans? tragd Air Cooling 3 July 13, 2010 02:20 PM
