Old June 28, 2012, 07:57 PM
Question Changing cooling need some fast answers
Hello there,
1- I wanted to change my current cooling for the Mastercooler 212+. My last cooling was using a backplate which had a sticker to stick on the mobo. (Something i will never do again..) So what i did is removing the backplate by hand which was really hard but ive succeeded! However, some glues and sticker part was left on the mobo and it seem that i can't remove them (without passing more than 6 hours on it) so if i decide to lets it that way can it cause any troubles ? (See pic #1) i believe not but just to be sure..
2- I also cleaned the CPU with some alcool isopropyl which succeeded aswell.. there some thermal paste (micro) in some corners but i decided to not remove the CPU just to remove them (See pic #2) i don't want to bend any pins.. then again i believe there no problem about that also does the CPU look enough clean ? I may seem a noob sorry but this is the first time i replace a cooling and i really want to go the right route and dont want to end up with a surprise later.. i know i am paranoid but well sometime a detail can be problematic later..
Thanks a lots for thoses that replies ! Really appreciated !
Changing cooling config. NEED HELP PLZ! Keltron 3030 Air Cooling 9 April 15, 2011 04:10 PM
changing cooling gingerbee Water Cooling 2 April 17, 2009 09:45 PM
AMD answers the 8800 GT... qwerty Rumor Mill 19 November 14, 2007 09:10 PM
The Barcelona is fast, REALLY FAST!: AMD Babrbarossa Press Releases & Tech News 2 April 25, 2007 08:02 AM
