-   Air Cooling (http://www.hardwarecanucks.com/forum/air-cooling/)
-   -   New cooler design. Looks promising. (http://www.hardwarecanucks.com/forum/air-cooling/55101-new-cooler-design-looks-promising.html)
Nodscene June 28, 2012 08:37 AM
Of course I wouldn't want to get a finger stuck in there.
The fanless heatsink: Silent, dust-immune, and almost ready for prime time | ExtremeTech
BigPhatPaulie June 28, 2012 08:41 AM
I was wondering how long this was gonna take to surface again... been like 3 years since I last heard about it
stoanee June 28, 2012 08:46 AM
1 thou clearance? Don't drop it or you will likely have a paperweight.
sswilson June 28, 2012 08:55 AM
Damn.... that might even switch me back from being a WC only dude..... ;)
No cats or young kids in the house so it wouldn't be a problem even on my open bench.
uberness June 28, 2012 08:59 AM
It sounds like a hard drive in the video. It's not silent at all. And I wonder if it will work properly if it's tilted at 90 degree angle in a tower case.
Soultribunal June 28, 2012 07:01 PM
That is one interesting cooler, something I would like to keep an eye on in the future.
-ST
Bloodystumps June 29, 2012 02:53 PM
It is silent, the fan it self makes no noise , its the motor that is noisy
uberness July 7, 2012 08:21 PM
Yeah but noise is noise regardless if it comes from the fan or the motor. If it going to sound like that in the final product then not many people will be interested.
frontier204 July 8, 2012 12:00 PM
I'm sure it will be great for servers (that can be as loud as you want it seems), but my more important concern putting this in the hands of consumers is if it will be fragile. It's essentially a flywheel with fins, and it would likely carry more momentum than spinning hard drive platters, so dropping or knocking over a device that uses this type of heat sink won't be pretty.
JJThomp July 8, 2012 04:20 PM
I'd like to use one of these, they should find a way to put these in an inclosure so you can pump water through it. Water will always be more efficient than air.
