Old June 22, 2012, 09:08 PM
Exclamation new noctua nh-c14+ none of my case fans not running at start up?
The title says it all. Should i wait a few minutes??? Will my i5 3570k overheat??
BTW i just built my computer...... i plug the 3pin to the 4 pin header on mb........ i JUST used a 2 to 1 adapter for both fans (noctua nh-c14) because it's easier to wire up..... but THAT shouldn't be the problem right? .... i plugged the 2 to 1 adapter to the cpu fan header on mb too ....any ideas?
This is my first time building a computer... sorry for silly mistakes =D
Old June 22, 2012, 09:25 PM
Shadowmeph's Avatar
Does the fan run on any other fan headers? the fan should come on know matter if the cpu is hot or cold just as long as the motherboard has power connected from the psu
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old June 22, 2012, 09:32 PM
This is very funny.... i mean i can go to bios ..... but no fans run... no case fans .... not the noctua nh-c14 heatsink....... idk what's wrong... i plugged everything in ...... i'm soooo confused here are my system spec if it helps
gigabyte z77x-ud3h
i5 3570k
noctua nh-c14
corsair 550d case
corsair vx550watts power supply
crucial m4 128gb ssd
kingston hyperx 8gb
Old June 22, 2012, 10:36 PM
Shadowmeph's Avatar
I have never heard of that happening before, have you tried only having one fan plugged in What I would do is pull the motherboard and set it on something outside of the case then try it there you .
Folder :
Old August 15, 2012, 02:22 AM
Hmm. I had this happen with my wifes Dell Studio 540 the other day when I removed the heatsink and cpu for cleaning. There was a piece of dust under the cpu between the cpu and the socket after I cleaned it up. It wasn't detecting the cpu. Maybe you are in the same boat. Maybe try removing the heatsink and check to make sure the cpu is seated properly and nothing is between the pins and the socket.
Start FAH, Stop FAH, Start FAH, FREEZE! frontier204 Troubleshooting 4 April 13, 2010 06:52 PM
[FS] Noctua NH-D14, Noctua NC-U6, Thermaltake Spirit RS alexroland Buy/Sell & Trade 1 April 11, 2010 01:09 PM
need help with i7/x58 start up kruzn4evr Troubleshooting 7 January 19, 2009 09:08 AM
About to start RainMaker New Builds 5 January 16, 2009 12:02 PM
Noctua-News: Noctua introduces NH-U9B CPU cooler Scotch Tape Press Releases & Tech News 1 February 25, 2008 06:33 AM
