-   Air Cooling (http://www.hardwarecanucks.com/forum/air-cooling/)
-   -   Silent case fans worth replacing? (http://www.hardwarecanucks.com/forum/air-cooling/54988-silent-case-fans-worth-replacing.html)
jiepo June 22, 2012 09:08 PM
I was wondering if it was worth replacing the 2 front intake fans on the Corsair 550d(or any other "silent" cases)
It is the only 2 intake fans that get air into the case and I'm on a small budget. Would you think they are worth replacing or should I just stick with only changing the heat sink fans?
Adzsask June 22, 2012 09:50 PM
If the budget is tight then stick to stock on the case, quieter fans aren't cheap, only use noctua, gentle typhoons , and cougar fans myself, but my good friend recently used prolimatech 140mm fans in his lian li and they looked/worked beautifully.
jiepo June 22, 2012 11:03 PM
how are the cougar fans airflow to sound wise
Adzsask June 22, 2012 11:19 PM
Very close to a gentle typhoon, little quieter and a little less airflow.
jiepo June 22, 2012 11:27 PM
and cheaper :P
thanks
NyteOwl June 23, 2012 09:48 AM
I have Scythe Slipstreams in my P182. They're pretty quiet as well.
jiepo June 24, 2012 05:51 PM
which do you guys think is better from your experiences?
the noctua nf-f12 or the gentle typhoons ap-15
uberness June 27, 2012 11:28 AM
I have the Noctua NF-F12 PWM. You can't go wrong with it. A little pricey but Noctua fans last a long time so it's worth it. I have a NF-S12 for 4+ years running 24/7 and it's still as quiet as the first day, while all other fans have worn out and making clicking sound.
