<~----> Heatsink problem - Hardware Canucks
Old April 9, 2008, 04:29 PM
Default Heatsink problem
Hi guys,
I am some terrible luck with my heatsink, Thermalright Ultra 120 Extreme with a Panaflo fan on an E8400, stock temps @ idle come to about $40-43C, and that is totally stock, no OC at all.. I want to test it with the stock Intel heatsink to see if its any better.. I bought the E8400 from eldonko, its running superb so I doubt its the processor..
This TRUE is lapped, I used the same lapped heatsink with my E6600 with some amazing temps, the E6600 used to run btw 25-30C idle.. So using the same heatsink with the E8400, dunno what's going on..
Intel Core 2 Duo E8400
ASUS P5N32-E SLI Nforce 680I
Crucial Ballistix Tracer DDR2 PC2-8500 2GB (2X1GB) DDR2-1066
XFX 8800GTS 512MB
WD 250GBx4 RAID 0 (WD250KS), Seagate 500GB SATA2.
Enermax Galaxy DXX 1000w
Gigabyte Aurora 570 case
That's my rig, and I also checked I have the latest BIOS for my board... I almost sick of this, I almost went to buy Arctic Cooling Freezer 7 Pro but I'm sure this TRUE is capable of much more..
Any ideas?
Old April 9, 2008, 04:31 PM
sswilson's Avatar
What kind of results do you get with the stock intel heatsink?
Maybe your new CPU isn't flat?
Old April 9, 2008, 04:33 PM
3.0charlie's Avatar
Which software are you using?
Old April 9, 2008, 04:35 PM
Your temps are fine.
I've got a 38mm x 120mm Sycthe Kraze on my Ultra 120 and I'm about 43-44' idle and about 56 or so under load.
Its not the idle that matters, its how it performs under load which is where the 120 shines.
Old April 9, 2008, 04:53 PM
Probably, but I guess most of the Intel processors are not flat...
I used Everest, speedfan, core temp, HW Monitor..
Well but most of the people I've seen using an E8400, run idle @ 30-35C, mine's about 10C more, and I understand what you say enaberif, but I mean if the idle temps are so high, I don't wanna fry something..
And I also thought that the new intel processors were supposed to run cooler..
Old April 9, 2008, 06:41 PM
People with sub 40 temps are usually water cooled or in a very cold room :)
Old April 9, 2008, 08:24 PM
Cptn Vortex's Avatar
Miggs, for the new 45nm CPUs those temp programs read wrong. Use Realtemp Real Temp - New temp program for Intel Core processors - XtremeSystems Forums
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old April 9, 2008, 10:19 PM
Well... to give you some idea..
HWMonitor:
Core 0 = 43'
Core 1 = 45'
RealTemp:
Core 0 = 32'
Core 1 = 32'
Everest:
Core 0 = 45'
Core 1 = 45'
Who do you believe? :P
Old April 9, 2008, 11:26 PM
The reason I only trust RealTemp is because of my stock idle temps, watercooled of course. When HWmonitor is reading 49 degrees idle at 1.22V, with my watercooling, then something is off. Real temp reads a more reasonable 33-35 idle. Makes sense to me
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old April 10, 2008, 03:57 AM
3.0charlie's Avatar
Could be a stuck sensor too.
