<~----> Sabertooth p67 50mm fan options - Hardware Canucks
Old June 5, 2012, 04:26 PM
Default Sabertooth p67 50mm fan options
Just wanted to see what everyone is using for the optional fan and where you were able to source the fan.
Old June 5, 2012, 04:37 PM
NSdeadly1's Avatar
Newegg.ca - Computer Hardware, Fans & Heatsinks, Case Fans, 50mm Just a quick search on Newegg.ca I'm sure there are more out there. The ones that cam with my z77 Sabertooth are surprisingly quiet, not sure who the oem is for them though.
Old June 5, 2012, 07:53 PM
Perineum's Avatar
NCIX has 1 50mm fan, I forget the brand... it works but they die every 6 months, it seems
Old June 6, 2012, 06:50 AM
I got mine from a local computer shop, not sure what the brand of the fan is but I bought 2 just to be safe I'll check it every once in a while to make sure its running (probably every 3-4 months)...
Comp1 (Mine) : ASUS P9X79 LE, 3960X, 16GB Corsair Vengence 1333, XFX 7970 DD, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : Intel DP67BG, i7 2600K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, Sapphire 7950 OC, Corsair 950W, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Sapphire 7970, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 1200
ASUS Sabertooth, i7 2700K, 8GB 2133 GSkill
i7 2700K & Sabertooth P67 (B3) trayton Overclocking, Tweaking and Benchmarking 1 April 26, 2012 05:38 PM
[FS] ASUS Sabertooth X79 Eldonko Buy/Sell & Trade 27 January 25, 2012 04:15 PM
[FS] FS: Sabertooth P67 Eldonko Buy/Sell & Trade 7 June 13, 2011 06:57 PM
sabertooth x58 not boot CTA Troubleshooting 43 March 4, 2011 12:48 PM
keep or sell sabertooth x58 CTA Off Topic 12 January 31, 2011 05:59 PM
