Old May 17, 2012, 12:55 PM
Default Picking Case Fans
When picking fans, what kind of things should one look at to determine if the fan is a good, bad or great fan? And how should specs like "1200rpm 35cFm+/-5" be interpreted as? Basically I'm looking to compare the fans that come with the case I will be using in my upcoming build (Rosewill Challenger U3) and the fan included with the Corsiar H60 against other available fans. I just dont want a situation like the one I'm in now where I buy a 120mm fan, but it turns out it doesn't really seem to do anything besides turn. (Referring to the Rocketfish 120mm fan I bought for my current PoS pc. Can't feel any air moving more then 3in away from the fan).
Thanks for the help.
Old May 17, 2012, 02:11 PM
BigPhatPaulie's Avatar
That seems to be the case for any good fan as well. once you get about 3in away or more the column of air from the fan disperses and you can no longer feel it. Doesn't mean its a bad fan thats just how it seems to work. The rating system usually works like this. As an example lets say the max rpm the fan in question will spin is 1200RPM. At that rpm the fan will be pushing 40 CFM (theoretical) +/- 5. All this " +/-5" means is that expect the cfm rating to be between 45 and 35cfm. As for good fans there are many. Coolermaster, scythe, noctua, bitfenix etc all make a good case fan. It all just depends on what you want to spend vs what you need in a fan
Hope this helped
FOR PONY..... that is alll
Old May 18, 2012, 01:32 AM
My best results have always been with Noctura as upgrades. I am not sure that is a common consensus as i hate the colour scheme but they seem to be working well.
Need help picking a case/fans for my New Build Siniq New Builds 5 March 12, 2012 10:48 AM
Picking a new case Greaseddog Cases 1 January 22, 2012 06:32 AM
Building a new gaming machine and need help picking a case Linus LinusTechTips Q&A 1 September 28, 2011 11:41 AM
Help picking out a case vagnaar HTPC Systems & Software 3 October 13, 2010 09:13 PM
Need some help picking a case bkh2 New Builds 30 February 7, 2010 05:11 PM
