Old May 13, 2012, 01:48 AM
ExpendableG4M3R's Avatar
Default 200mm that fit 180mm placement? Arc MIDI
I am curious if there are any 200mm fans out there that will fit in the 180mm fitting on the Arc MIDI. I've been reading that some do and some dont. Common sense dictates that 200mm does not fit 180mm, heh. If I got this case I want to fit a big LED top fan and move the one that comes with it to the front.
So far all ive found is a Silverstone FN181-BL.
Old May 13, 2012, 11:12 AM
Have you looked and the Bit Fennix Spectre Pro series? The fans themselves have quiet a few mounting options.
Asus Rampage IV Extreme | Intel i7 3930k | Crucial 4x4Gb | OCZ Vertex 3 MaxIOPS 240GB | WD Velociraptor 1TB | AMD R9 290 Crossfire | Win10 Pro 64 | EK Supremecy | 2 x Alphacool XT45 360 | 2x Liang DDC 3.25 | Swiftech Malestorm Res | Case Labs M8 |
Old May 13, 2012, 02:39 PM
I saw those they just didn't mention any 180mm support but maybe if I email NCIX they can confirm. I'll look into those, thank you.
Old June 2, 2012, 01:11 AM
i believe the support is 200/230mm mounts. the 180 would be phoyba, magicool, silverstone (ap-181 best option), and NZXT.
airdeano
2x 180mm rad from magicool, available anywhere in Canada? Evochuck Water Cooling 4 October 20, 2011 11:09 AM
[WTB] 180mm or 240mm Radiator Shozzking Buy/Sell & Trade 7 October 9, 2011 11:17 PM
180mm Fans Soltez Air Cooling 9 September 23, 2011 07:07 PM
Fan adapter brackets? 200mm to 180mm fenix629 Air Cooling 3 August 3, 2011 06:31 AM
180mm fans JD Air Cooling 4 September 14, 2009 05:58 PM
