Old April 18, 2012, 12:56 PM
great_big_abyss's Avatar
Somebody should come up with a fan design that has the fan motor in the outside casing instead of in the center. The blades would be joined together by an uninterrupted circle around the radii's circumference. A high speed motor could use friction to spin the fan at low (quiet) speeds. This would negate the need for arms, and you could make the two sides of the fan symmetrical (stickers, whatever)
Old April 18, 2012, 01:11 PM
Soultribunal's Avatar
They should make it like a Turbo Prop. Though that might result in lost fingers.
-ST
www.realhardwarereviews.com
Old April 19, 2012, 05:03 AM
Silent_Avenger's Avatar
Well I was really hoping that someone would make a fan like normal but have the fins flipped the other way so the blades would still be sweeping forwards and still have optimal efficiency instead of just having a regular fan go in reverse.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old April 19, 2012, 10:05 AM
KaptCrunch's Avatar
a reverse flow look CW and CCW rotation fans
what size of fan we talking here 80mm 120mm 160mm ?
or use squirrel cage fan if have room
Old April 19, 2012, 07:15 PM
It's for the top 3 fan spots for the CM Cosmos S so it's very easy to see top fans especially since the case is pretty much on the floor.
Old April 19, 2012, 08:11 PM
yycraven's Avatar
-ST
Just remember a turbo prop the blades change pitch so the flow of air goes in reverse.
In any case you could design a fan blade in a way that they would make air flow the same amount in forward or reverse.
Old April 19, 2012, 09:02 PM
sswilson's Avatar
Yeah, all that needs to change here would be the pitch of the blades from one direction to another (assuming symetrical design of blades). This is driving me nuts... I'm sure I've had a few fans that were the reverse of standard, but no amount of google fu is coming up with something useful. ;)
Old April 19, 2012, 09:38 PM
yycraven's Avatar
You know if you had a small servo in the area where motor is you could make blades change pitch
the servos now a days do come pretty small. Then have a control on the front of your case with a knob that controls the speed and direction of the fan.
I have been doing the same thing with no luck as well. I know I have seen some but, you think I could remember where..
  #19 (permalink)
Old April 19, 2012, 10:33 PM
You can't change the pitch of the blades. You would have to completely remold the blades to work opposite to how they are now.
Here 120mm Silent Reverse Fan K0001
  #20 (permalink)
Old April 19, 2012, 10:46 PM
Yes exactly like those but with the mounts on the other side of the fan.
Double Dragon Case Mod-reverse double ATX) Dalchi Frusche Case Mods, Worklog & Gallery 6 August 13, 2015 10:20 AM
Ottawa to reverse CRTC Internet billing decision Mark Press Releases & Tech News 66 February 19, 2011 04:35 PM
Ultra Kaze Fans in CM690 - Insane airflow!! mgroussel Air Cooling 8 December 7, 2009 11:11 PM
Reverse descrimination. tzetsin Off Topic 32 July 5, 2009 05:57 AM
New case airflow tubabub New Builds 11 July 2, 2008 08:28 PM
