Originally Posted by Adzsask Like enaberif said it is to late to save, future reference though, lift the sticker a couple times a year and put 1 drop of thin oil (sewing machine, all purpose) on the bearing, I have some 7+ year old fans that work like new still, oil FTW. |
Thanks for this info. It's good to know.
I finally replaced the fan. I would like to know which each fan is doing, the rpm and cooling delivered etc.
How do I do that?
I guess a fan controller? I found the cheapest ones to be about $30. Well, it's with LED.
Scythe Kaze Master Pro KM03-BK - $35.
Is that a good choice? Or should I ask, is it worth it? There's different model #s so what's the difference?
EDIT: I tried running Speedfan. I have this:
Sys Fan: 2033 RPM
CPU0 Fan: 2009 "
Aux Fan: 3041 "
Aux1 Fan: 1534 "
Aux2 Fan: 0 "
" = RPM
I'm not sure what those mean or which fans they are indicating and why is one '0' and how do I figure out which? :)
