Old June 27, 2012, 09:28 PM
Trial Member
Exclamation
Originally Posted by ipaine View Post
Ok, hopefully people can get me some thoughts quickly as this is a somewhat rushed system, have to get what we want in for a proper quote this afternoon.
Anyways I am looking at a system with the Asus Sabertooth X79 board and most likely a 3960X for the chip. There is still a chance that the chip could go down to the 3930K though. Also there will be a full set of 8 sticks of RAM in there so be aware that we have to consider clearance.
Anyways this machine is going to be doing some very serious number crunching and will be running utilizing all cores very heavily for days at a time. So because of that I need a good cooling soluition, what do you guys think I should go with?
It will be housed in a Corsair 400R case so airflow is not an issue. I am trying to decide on what to use, I have thought about something like the Corsair H100 or maybe the Intel Liquid cooler? Or what about straight air? Any options? Maybe something like the Noctua NH-D14?
Any ideas and options welcome, and thanks for quick responses.
Oh and as for noise level, quieter is better, but not a huge deal.
I'm about to build the sabertooth x79, corsair h100, in a corsair 400R. Were you able to mount the h100 in the 400r with the board and not have any clearance issues? According to this video, it looks like he had to go to a bigger case. I'm a little worried now.
Corsair H100 Hydro Series CPU Cooler - Overview and Installation - YouTube
I need a better solution - M-ITX cooling Dr_BenD_over Air Cooling 7 February 4, 2011 06:44 PM
EVGA GTX 280 Cooling Solution Rison Video Cards 15 February 11, 2010 06:53 PM
5870 Cooling Solution mattlef Air Cooling 8 February 3, 2010 08:57 AM
Most Powerful Cooling Solution? Wall86 Water Cooling 22 October 20, 2009 03:12 PM
Cooling Solution for Pentium D 3.6 wpurcell Water Cooling 7 July 11, 2007 09:30 AM
