Old March 22, 2012, 05:14 AM
Default Replacing HAF-X fans
Hi everyone.
Yeah another case fan question. I find my HAF-X pretty silent but I'd like to lower temps a little bit and have maximum air flow. I have stock fans on it.
Normal operating temps while playing demadning games (such has Crysis2 and SWTOR (in some areas)): CPU 35~40ish, GPU#1 70ins, GPU#2 80ish
For which model should I go (let's say I replace all fans)
XtraFlo 120 Red LED - Cooler Master - Leading Provider of Computer Case | Cooler | Power Supply
XtraFlo 120 Slim - Cooler Master - Leading Provider of Computer Case | Cooler | Power Supply (For top since space is thin)
Turbine Master MACH1.8 - Cooler Master - Leading Provider of Computer Case | Cooler | Power Supply
Excalibur - Cooler Master - Leading Provider of Computer Case | Cooler | Power Supply
MegaFlow 200 Red LED Silent Fan - Cooler Master - Leading Provider of Computer Case | Cooler | Power Supply
Ok yeah, these are all CM choices. Please bring up any other choice you would find useful but I would still want to know which of these are the best to use.
Note: I still want to have a silent rig.
Thanks all!
Mayoo
Gameplay > Graphics ... oh wait
Food > Gameplay > Graphics > Movies > Sleep > Work
Old March 22, 2012, 05:41 AM
supaflyx3's Avatar
Scythe Gentle Typhoon 1850RPM 59CFM @ 28db Fan Scythe Gentle Typhoon 1850RPM 59CFM @ 28db Fan [D1225C12B5AP-15] - $22.99 : DazMode, The Best Canadian PC Watercooling and Modding Store!
a bunch of those will do fine.
Old March 23, 2012, 07:31 AM
It is an interesting choice if I lower the sizes. I know CM augmented their numbers so the 110CFM on their MegaFlow is not reality. I also came up on the following BitFenix fans that looks pretty good from what I read (looking @ 230mm). They have better bearing and seems to get better CFM. Anyone has experience with those?
Oh I almost forgot. My final plan, for now, would be to put the stock side fan as the second top fan on the case and to get a new side fan. That's all.
BitFenix.com » Products » Accessories » Spectre Pro LED
BitFenix.com » Products » Accessories » Spectre LED
Mayoo
Replacing the HDD In My Studio 15 w/ a SSD AmuseMe Storage 5 March 18, 2012 03:00 PM
replacing psu fan? andyhan95 Power Supplies 6 March 6, 2012 03:36 PM
Replacing the fan on this, would it work? Blu Air Cooling 7 April 3, 2011 10:22 PM
Replacing NH-D14 stock fans? tragd Air Cooling 3 July 13, 2010 02:20 PM
Replacing 6yo Rig Adciv New Builds 8 February 18, 2010 09:33 PM
