<~----> The 120mm fan question (dual-fan) - Hardware Canucks
Old March 21, 2012, 04:49 PM
CMetaphor's Avatar
Quadfather
Default The 120mm fan question (dual-fan)
can ya tell I've been out of the game for a while? haha.
So, recent bought Bulldozer. Seems to be stable at 4.5Ghz, all cores, under my Zalman flex with AC5 and two 120mm fans.
The problem? Far warmer than I'd like. With two Coolermaster R4s im hitting low 70s using Prime95 "max heat" bench.
I have some alternate fans available:
-Gentle typhoon AP-14s
-Gentle typhone AP-30s
-Scythe S-Flex 21s (not sure which model exactly, think its the 2100 rpm one)
-Coolermaster Excalibur
Which would you choose for a dual-fan setup? Im not planning on OCing much higher. Noise isnt a Huge factor, but id rather not have it screaming.
Note: I checked and it seems my AP-30s have the 4th solder pad available to convert them into PWM controlled. Perhaps the best bet?
Old March 21, 2012, 05:05 PM
Adzsask's Avatar
The only above mentioned fan that would push more air then the R4's is the S-flex 2100RPM's, and I see it only lowering temps 2 C, I would re tim the CPU first before buying more fans, the R4's push quite a bit of air already.
Old March 21, 2012, 05:42 PM
You aren't going to see much better performance with a Zalman Flex, no matter what high performance insane RPM fans you use. The cooler's design/fin density simply can't take advantage of it. Most Zalmans are designed for low static pressure quiet operation.
[WTB] Dual 120mm/240mm rads geoc Buy/Sell & Trade 0 December 8, 2011 08:25 PM
dual pump question again clshades Water Cooling 9 December 3, 2011 09:42 PM
nVidia dual monitor question Squeetard Video Cards 2 January 14, 2009 11:16 AM
Dual Display question.... SiDiX007 Display Units 3 November 20, 2008 10:32 PM
Dual boot question SpateD O/S's, Drivers & General Software 17 March 8, 2008 05:11 PM
