I give up. I'm a dummy. In the meantime, I'll try to solve or improve the situation.
I'm just wondering how you set up a push/pull and how to troubleshoot if there's any cooling problems.
The cpu temp shows 46 degrees in the BIOS. Isn't that pretty high for using two fans?
I looked on google images for a good picture on how it should look but I suppose I need to arrange or place the fans accordingly.
It's a tower cooler so fan should push air through the heat sink (at the front) and then 'pull' it towards the exhaust fans at the back of the case?
I'll be so glad to go to a Corsair H-series liquid cooler even though it's not custom loop. I don't mind a cheap closed loop cooler for my cheap hardware. Heck, maybe I'll get lucky and shave some more degrees off.
I'll be looking for a H60, probably.
In the meantime, I welcome any advice or teachings about the setup. Any pictures or explanation is a bonus but I'm much better with visuals. Google images gave me a good idea so I'll just have to take a look at what I set up. I have two fans. One is a Thermalright fan holder and the other is my own custom elastic band attachment. :-) It was too difficult to get the wire clips in the hole that's way into the case. Has anyone else ever done it this way? :)
I notice most of the discussions are with newer hardware and I'm very jealous! But, why do you guys still use air cooling?!?
Thanks for any replies. I know my problem is dull and uninteresting. :)
