-   Air Cooling (http://www.hardwarecanucks.com/forum/air-cooling/)
-   -   Will This CPU Cooler Fit In My Case? (http://www.hardwarecanucks.com/forum/air-cooling/51542-will-cpu-cooler-fit-my-case.html)
Mark Romero February 12, 2012 08:33 PM
Hi I have a zalman z9 plus case and i was wondering if the Noctua NH-D14 will fit in it. if these matter i have an asrock Z68 Pro 3 Gen 3 1155 motherboard and a EVGA GTX 570. Thanks in advance! :)
Mark Romero February 14, 2012 05:16 PM
Anyone?
ilya February 14, 2012 08:13 PM
Don't know if it will fit the board, but it should fit the case. Z9 has over 160mm clearance, the D14 was less than that IIRC.
Check the Noctua website for board compatibility and to make sure I'm not wrong about the height.
supaflyx3 February 14, 2012 08:17 PM
The NH-D14 is 160mm tall, i wouldnt risk it.
Mark Romero February 15, 2012 01:20 PM
oh thank you guys yeah i think ill just go with the corsair h-80 thanks again
