Old March 18, 2008, 07:21 PM
Scart's Avatar
Default Isopropyl Alcohol
So I'm going to be getting a new cpu cooler, and I stopped by the drugstore to get some isopropyl alcohol, which i hear is the best thing to use, but they only have 70% Is that enough or does anyone know where to get a higher percent?
Old March 18, 2008, 07:23 PM
3.0charlie's Avatar
It's fine - 95% is better though. When cleaning, simply wait a little while longer to make sure that the water has fully evaporated before applying the thermal paste.
Hydro-Quebec is salivating...
Old March 18, 2008, 07:25 PM
sswilson's Avatar
The 70% isn't ideal as it has oil in it which will leave a film on the surface you are cleaning.
Double check with the drugstore (or check another one). I found mine at Wally mart.... :)
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old March 18, 2008, 07:28 PM
biff's Avatar
I assume this is to clean off the old gunk? The 70% should be just fine, just make sure it's only isopropyl and not rubbing compound as I think sswilson is refering to since that has extra junk in it. I would imagine acetone (main ingredient in nail polish remover) would probably work well to, Crappy Tire sells the pure stuff but I think plain old nail polish remover would be fine if it isn't laced with perfumes and such. Be aware that acetone doesn't play nice with all plastics.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old March 18, 2008, 07:32 PM
Supergrover's Avatar
Same Steve, it's the 99.9% Equate brand.
R.I.P.
Old March 18, 2008, 10:40 PM
i found 99.9% at the local shopper's drug mart. The one on steeles between leslie & bayview (in toronto). I'm sure other shopper's drug marts carry the same one though since they're a chain store. thing about 99.9% is it evaporates much faster than 70%, so less waiting around.
Desktop: 4790k @ 4.6GHZ | Noctua NH-D14 | 16GB (2x8gb) Crucial Ballistex @ CL9 | Asrock Z97 OC Formula | Gigabyte GTX 670 SLI | 250gb Samsung 840 Evo & 240gb OCZ Vertex 3 MI & 2TB WD Black | Auzentech Forte 7.1 | Seasonic 760wt Platinum | DELL U2711 @ 1440p | Corsair 300R | Win 8.1
Ultrabook: Zenbook UX32LN | i5 4200u | 8GB RAM | Nvidia 840m | IPS Matte @ 1080p | 256GB SSD | Win8.1
Old March 18, 2008, 10:48 PM
Eldonko's Avatar
Hardware Canucks Reviewer
I use methyl hydrate myself, have for years, $2.50 a jug at home depot.
Old March 18, 2008, 10:49 PM
Some drug stores may NOT sell it due to the fact its used in making drugs :)
Old March 19, 2008, 12:05 AM
1Tanker's Avatar
I use 70%...works great, if it leaves oil, i can't see or feel it... and my temps are always good. It's an old bottle (5 y.o), but i have 2-90% bottles at the ready.
Edit: I don't always follow accepted procedure. I still spread my TIM's...i found no benefit to the rice grain and twist method, or the straight line up the middle method.
Old March 19, 2008, 03:24 PM
Scart's Avatar
Yeah, my shoppers only had 70 percent and it would not surprise me about the whole drug making thing.
EDIT: Checked out walmart, they only had 70 and crappy tire didn't have it at all.
EDIT EDIT: Totally forgot we have a Rexall, they have 99 but they are currently sold out :( Hopefully they'll have it in by sunday.
