Old March 17, 2008, 04:21 AM
Default cpu cooler weight question in.......
i will soon be going from a socket 478 to 775.
on my old motherboard (before i fried it) the max weight of cpu cooler was 450g.
now that the coolers ( on 775) actually go through the motherboard instead of hooking onto clips i was wondering if the max weight had increased.
i saw some of the reviews here. i intend to mount my motherboard vertically like most cases. some of the reviews had massive coolers mounted vertically on the motherboard which means all that weight basically hanging down or if you will pulling on the motherboard.
hence my question on weight of the cooler.
thx for any info
rob123
Old March 17, 2008, 04:51 AM
Mr. Cipher's Avatar
I have one of the massive ones, the Thermalright Ultra 120 Extreme, weighing in at 790g without the fan. There is no torquing on my motherboard, and it sits quite comfortably without causing me any concern.
Admittedly I do not know if there is a max weight, but at least you know that the 775 mobo's can handle the big boys like mine. At worst, take a look at people's signatures and their CPU cooler, take a look at the manufacturer's website for the weight, and you'll get a good idea what the max is.
Sorry I couldn't answer it with a clear xxx grams max.
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | BFG GTX 295 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Intel E1xxx & E2xxx OC Thread
Old March 17, 2008, 09:55 AM
Cardboard box with DSL's Avatar
For S775 you dont really have to worry about cooler weight, because any good high performance cooler that weighs a ton will come with a back plate for your motherboard. The backplate reduces the strain on your motherboard by a fair bit.
Old March 17, 2008, 01:31 PM
CanadaRox's Avatar
If you feel your motherboard does have too much weight on it (looks like its flexing or something) you can always use some string or zip-ties and attach it to the top as well to help support a bit of the weight. But most coolers are huge and are fine to mount normally. My old Scythe Infinity only had the 4 regular clip things that the Intel stock coolers had, and it was fine.
Project: Black and White
Old March 22, 2008, 06:49 PM
thx to all for the replies. will keep them in mind when i make the switch
rob123
Old March 22, 2008, 07:56 PM
sswilson's Avatar
Heh... once you get that aftermarket cooler on there, it'll be time for some Overclocking.......
Old March 22, 2008, 08:30 PM
magictorch's Avatar
Remember the the choice of fan makes a big difference too- e.g. the NF-P12 is a heavy fan. Put two of those on a sythe ninja rev b with push-pins and your looking at a nice weight on the MB...mind you the asus p5ke doesn't mind being bent a little bit.
Cooler Master Hydra 8800 GPU cooler (water block?) discussion thread Misoprostol Water Cooling 9 December 7, 2007 11:27 PM
Cooler for EVGA 680i SLI...and NCIX question dheian CPU's and Motherboards 11 July 12, 2007 02:24 PM
Another peculiar GPU cooler from Cooler Master: CoolViva Pro Review by X-Bit Babrbarossa Reviews & Articles from the Web 7 March 19, 2007 04:19 AM
