Old January 11, 2012, 07:47 PM
bigFOIG's Avatar
Default Fan controller that doesn't use a front 5.25" bay
I'm using a 600T case and I'll have a total of 10 120mm fans in it. What options do I have if I need a fan controller? The catch is that I don't want to use anything that would show up on the front of my case. I'm trying to keep it slick looking, with no cd/dvd drive or anything. If it makes a difference, support for at least 6 fans would be good enough. I don't mind using the 600T built in fan controller for 4 of the fans, which is the maxiumum it supports.
I assume that if I get a bunch of splitters and use them with the 600t integrated fan controller, the voltage would be split between the fans? I actually don't mind that, because I want to undervolt all my fans anyway. Something tells me that this isn't a good idea though.
Old January 11, 2012, 07:49 PM
sswilson's Avatar
What about a standard 5 1/4 bay controller mounted internally? (or a 3 1/2" if your HDD bays will accept one?)
Old January 11, 2012, 07:55 PM
Supergrover's Avatar
What about something like this:
Alphacool Heatmaster II Products Model: 26153 [26153] : Performance-PCs.com, ... sleeve it and they will come
I thought there was a just fan one without the pump options out there but cant find a link right now.
R.I.P.
Old January 11, 2012, 08:00 PM
bigFOIG's Avatar
That's a good idea. I might do that.
Now why is this so expensive? I really like this type of solution though.
I would like to spend as less as possible. :\
Old January 11, 2012, 08:25 PM
Birk's Avatar
NZXT Sentry Lxe High Performance External Touchscreen Fan Controller Black - NZXT - SENLXE-001
Old January 11, 2012, 08:28 PM
I have had a chance to use this unit and I cant recommend it, the touch is garbage, nice concept but got pulled and put in storage after 1 week.
As for why the unit is so much really it is a 30w per channel 6 fan connector with pump control and monitoring, I can see why it is that price. Would I pay that ? Doubtful but I can see why it isnt cheap.
R.I.P.
Old January 11, 2012, 09:03 PM
lowfat's Avatar
You could use an Aquaero LT w/ the mounts for it. Both will run about $100 though. But it sure is awesome.
Old January 11, 2012, 09:42 PM
bigFOIG's Avatar
Would love to have that. It really does seem awesome, but I just don't have the money.
Scythe Kaze Q12 12-Channel Fan Controller, Black at Memory Express
Scythe Kaze Q8 8-Channel Fan Controller at Memory Express
These seem pretty nice and simple. The Q8 one is mountable on hard drive bays, which would be perfect for me.
Old January 11, 2012, 09:48 PM
Can you mount it recessed in the case and then pop out that drives cover? Depending on the case might be easier than a internal mount that you would have to pull the side off. Just a idea.
R.I.P.
Old January 11, 2012, 09:58 PM
Do you need variable control? If not: Fractal Design PCI-MOUNTED Fan Power Splitter - Converts One 4PIN Molex to 16 Connectors - Fractal Design - 5321185
If you do, I believe Sunbeam made a PCI mounted controller that could handle a ton of power on 2 channels. You could probably run a large amount of fans off one channel.
Suggest me a black 5.25" front bezel with.... kosmic Cases 5 October 11, 2011 09:23 AM
How do i know if my "Drive Controller" is running in "AHCI mode"? Teo3201 Storage 2 October 8, 2011 09:54 PM
Xbox 360 controller doesn't work in Full Speed Troubleshooting 3 May 22, 2010 07:40 PM
"Your CPU fan doesn't work properly. You must turn off your system right now and chec _dangtx_ HardwareCanucks F@H Team 14 March 15, 2010 02:38 PM
[WTB] 5.25" Fan controller 0o0 Buy/Sell & Trade 2 January 28, 2010 01:57 PM
