<~----> Fan controller that doesn't use a front 5.25" bay - Page 2 - Hardware Canucks
Old January 11, 2012, 11:06 PM
bigFOIG's Avatar
Originally Posted by Supergrover View Post
Can you mount it recessed in the case and then pop out that drives cover? Depending on the case might be easier than a internal mount that you would have to pull the side off. Just a idea.
Yeah, I think the Scythe Q8 is supposed to be used like that. Mounted in the case, but with the face on the front of the case's external. But that's not what I want. I want my front panel untouched. 600T's side panel takes less then a second to open, so it won't be a problem for me. Just some latches.
Originally Posted by ilya View Post
Do you need variable control? If not: Fractal Design PCI-MOUNTED Fan Power Splitter - Converts One 4PIN Molex to 16 Connectors - Fractal Design - 5321185
If you do, I believe Sunbeam made a PCI mounted controller that could handle a ton of power on 2 channels. You could probably run a large amount of fans off one channel.
I saw this earlier when I was looking around, but I don't like the design. I would have to run cables out to the PCI area of the motherboard which will expose a lot of wiring.
Old January 11, 2012, 11:26 PM
bigFOIG's Avatar
Originally Posted by sswilson View Post
What about a standard 5 1/4 bay controller mounted internally? (or a 3 1/2" if your HDD bays will accept one?)
Ended up borrowing your idea. Will pick up one of these. Scythe Kaze Q8 8-Channel Fan Controller at Memory Express and I'll pop it in one of my hard drive racks. It's a good thing that the hard drive bays are facing you when the side panel is opened in the 600T.
Old January 12, 2012, 03:52 AM
sswilson's Avatar
Glad to hear it. Sometimes the most obvious solutions are too simple for us to see them. I never had a fan controller mounted internally, but I did have a floppy facing back towards the motherboard back in the day(s) when the only thing we used a floppy for was bios updates.
IMO, most folks don't do much fan speed adjustment once the novelty wears off so I predict you won't be taking the case side off all that often. :)
Old January 28, 2012, 07:56 AM
goldry's Avatar
What about something like this:
Alphacool Heatmaster II Products Model: 26153 [26153] : Performance-PCs.com, ... sleeve it and they will come
I thought there was a just fan one without the pump options out there but cant find a link right now.
Is anything like this with Mac OS support?
Suggest me a black 5.25" front bezel with.... kosmic Cases 5 October 11, 2011 09:23 AM
How do i know if my "Drive Controller" is running in "AHCI mode"? Teo3201 Storage 2 October 8, 2011 09:54 PM
Xbox 360 controller doesn't work in Full Speed Troubleshooting 3 May 22, 2010 07:40 PM
"Your CPU fan doesn't work properly. You must turn off your system right now and chec _dangtx_ HardwareCanucks F@H Team 14 March 15, 2010 02:38 PM
[WTB] 5.25" Fan controller 0o0 Buy/Sell & Trade 2 January 28, 2010 01:57 PM
