Old January 4, 2012, 09:32 AM
taimoorali007's Avatar
Default Which cooler under budget?
*M REALLY SOOORRRY FOR POSTING AIR COOLING THREAD IN WATER COOLING, PLZ DONT MIND, I'LL BE CAREFUL FROM NEXT TIME!!*
Hi guyz,
Actually m using i5 2nd gen on stock setting so suggest me any cooler for cpu LGA1155 under 20-40 bucks!
Thanks!!
Some of my options are:
CM Hyper 212 Plus
CM Hyper N520
CM Vortex Plus
Old January 4, 2012, 09:50 AM
bigFOIG's Avatar
I'm pretty sure that the 212+ is the best air cooler you can get in that price point. I haven't heard of your other two though.
Old January 4, 2012, 10:43 AM
gingerbee's Avatar
hyper 212 is a great little cooler
Old January 4, 2012, 11:11 AM
Zer0's Avatar
Hyper 212+ EVO
Cools a little better than the older 212+ but also a little more expensive.
Old January 4, 2012, 12:08 PM
Thnx guyz!
Old January 4, 2012, 07:12 PM
I have the Hyper 212+ with 2 of the stock bladmaster fan for a little push/pull love, and I tell you, it cools extremely well. I have a Raven 3 case, and mentioned cooler along with MX4 paste. It keeps my 955BE 1.43v 4.2Ghz at 47c or less(I really do not do benchmark runs, just gaming, average hottest is 45c with bitcoin/bf3)
The EVO is supposed to cool a bit better, but is also a bit more expensive, I would just get the hyper 212+ and dual bladmaster fans(I believe they are the 68cfm models?) excellent cooler for its low price, and, you can slide the fans up/down to correct memory height issues if need be, for me, slid all the way down, it keeps the motherboard very cool as well as the ram :)
Old January 4, 2012, 09:42 PM
As m in asian countinent, so in my country MX4 isnt available i think but what about CM nano fission or any paster by Artic cool?
Old January 4, 2012, 09:45 PM
Can we attach CM 120mm LED Fans with cooler Hyper 212+?
Old January 4, 2012, 10:09 PM
yes
and get the 212
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old January 4, 2012, 10:25 PM
If you're in an Asian country, try looking for a Scythe Mugen. Would probably be around the same price point.
Cooler Master Announces CM Storm Strike Force 19 Gaming Notebook Cooler FiXT Press Releases & Tech News 3 October 26, 2010 01:48 PM
Upgrade from ZALMAN CNPS10X Performa cooler to Corsair Hydro H70 cooler completed dosmond Water Cooling 3 September 3, 2010 02:27 PM
Budget build. Epmphasis on budget. Miek New Builds 6 February 4, 2010 09:46 PM
This Budget AMD vs. Budget Intel AmuseMe New Builds 23 December 22, 2009 05:44 PM
Cooler Master Hydra 8800 GPU cooler (water block?) discussion thread Misoprostol Water Cooling 9 December 7, 2007 11:27 PM
