Old March 10, 2008, 03:33 PM
yycraven's Avatar
Default OCZ Vindicator
So I'm wondering what you guys think of the OCZ Vindicator, I just bought it today and not yet put it on. But wondering if I should have gotten the Thermalright Ultra 120 or not.
let me know what you guys think, if this was a good choice or not.
thanks
Old March 10, 2008, 03:45 PM
Mr. Cipher's Avatar
here is a comparison of the vindicator to other aftermarket CPU HP solutions. Keep in mind that the temps are higher since its an x6800.
here
Hope that helps. Doesn't seem like a bad piece of hardware.
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | Radeon HD 6870 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz |
BFG GTX 295 | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Old March 10, 2008, 04:14 PM
yycraven's Avatar
I guess, should have gotten the Ultra 120. hmm maybe tomorrow I should bring this back and get the Ultra 120 instead.
I will have to think about this.
thanks for the site.
Old March 10, 2008, 05:56 PM
Take a read here, Top 5 Heatsinks (AMD/Intel) on FrostyTech good reviews and great reads for nothing but coolers.
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
Old March 10, 2008, 06:27 PM
yycraven's Avatar
I like the coolmaster hyper 212, they had one of those at the OTV store. maybe I will return this for that one.
that review was good, maybe this is the one. to many choice's..lol
Old March 10, 2008, 06:38 PM
sswilson's Avatar
Hmmmmm
I had a Hyper 6+ on my S939 rig before I switched to water. Great to see that Coolermaster is continuing on with that tradition.
Old March 11, 2008, 06:43 AM
I have an OCZ vindicator on my Q6600, I have no complaints about it other then the 120 fan they supply with it, which is noticeable for its silence, not its cooling. At Idle, my Q6600 at 3.2ghz idles around 34'ish, under load it gets into the high 40's, low 50's.
Q6600@3.2ghz
Asus P5N32-E Sli
4gb OCZ Platinum DDR2 @1100mhz
Antec P180
BFG GTX 260 Core 216
Corsair HX-620
Thermaltake Power Express 250W
Raptor150, WD 500gb. WD 300GB
X-Fi Extreme Music
Old March 11, 2008, 11:26 AM
yycraven's Avatar
Ok so I figured I would try the Vindicator, well I am not impressed with it at all, my temps are higher then with my stock cooler.
So I think this pay day I will buy the Thermalright Ultra-120 Extreme. with stock cooling my idle temps were 45 to 46C, now they are 50 to 52C
and at load they would hit 60 to 61C now on load they hit 78 to 83C
whats with that
I put a antec 120 fan and put it on high setting.
here is a pic of my set up
Old March 11, 2008, 12:22 PM
Did you clean all the previous thermal compound from the CPU? All the retention clips are locked in?
Your temps should be a lot lower then that.
Q6600@3.2ghz
Asus P5N32-E Sli
Antec P180
Corsair HX-620
X-Fi Extreme Music
Old March 11, 2008, 12:42 PM
yycraven's Avatar
well thats what I thought as well, yes I took the old thermal off and put fresh on.
the Vindicator seems locked down good. Yes they are locked down good.
I do not know
OCZ Vindicator: Heatpipe Tower Cooling from OCZ by Anandtech Babrbarossa Reviews & Articles from the Web 0 April 6, 2007 09:45 AM
The OCZ Vindicator CPU Cooler Review by Legit Reviews Babrbarossa Reviews & Articles from the Web 4 March 15, 2007 03:18 PM
