Old December 26, 2011, 12:47 AM
taimoorali007's Avatar
Default Better airflow direction for my case: SilverStone SST-PS05B
Hi guyz,
I recently purchased a case PS05B and unlike Antec 300 or any budget case like CM Elite 371, it only has one 120mm fan in front, two on the top, one at rear and one at bottom near to power supply. According to this, plz tell me the suitable no. of fan i should use and tell me the airflow and direction of fans for my case to keep it quite cool! :)
Thanks!
Old December 26, 2011, 05:04 AM
front, top, rear.
front blows towards rear
rear out of case.
top is either in or out depending on your temps
Old December 26, 2011, 05:33 AM
Ok, but wha u'll say about positive/negative airflow, do they make sense?? As i heard negative airflow is more dusty :P (on Tomshardware)
Old December 26, 2011, 08:53 AM
Adzsask's Avatar
front to back, and bottom to top always want the heated air going out the back, or up as soon as possible before case ambients get to warm. Positive flow means you have more intake then exhaust, or you have faster intake then exhaust, and yes it makes a big difference in cooling and cleaning.
Old December 26, 2011, 09:58 PM
According to where i m livin, Temp is slightly low but dusty environment, i set up positive airflow for clean internal environment according to this.
SilverStone Technology Co., Ltd.
What u'll say bout this silverstone guide?
Old December 27, 2011, 06:29 AM
I try for positive airflow at all times.
Slightly more air going in than going out. In my setup (water cooling) I have 3 fans blowing out the top which is ideal as heat rises. 4 fans blowing in. Front 120mm (hdds) blowing in. Side 200mm fan blowing in. Rear 120mm blowing in (helps with mosfets/vregs) and a bottom 120mm which basically blows the hard drive heat straight up. I lose a bit on the bottom because of the filter but that one has gotta be filtered with my desk setup.
With cpu air cooling the rear 120 should be blowing out... basically you don't wanna blow cold air in as much as you want to get the hot air out but in my humble opinion it is better to have a bit of internal pressure to help get the hot air out which keeps the dust down. Heat removal is ideal.
Because I water cool I lack the internal airflow a normal cpu cooler generates. A push pull setup for example would blow air past the cpu mosfets and keep them cool always. I don't have that so to counter that problem I reversed my rear 120mm fan. I have next to no dust problems with a slightly positive setup.
My stuff for sale.
Mah Rig
Old December 27, 2011, 06:37 AM
Slightly more air going in than going out. In my setup (water cooling) I have 3 fans blowing out the top which is ideal as heat rises. Front 120mm (hdds) blowing in. Side 200mm fan blowing in. Rear 120mm blowing in (helps with mosfets/vregs)
With cpu air cooling the rear 120 should be blowing out... basically you don't wanna blow cold air in as much as you want to get the hot air out. Because I water cool I lack the internal airflow a normal cpu cooler generates. To counter that problem I reversed my rear 120mm fan. I have next to no dust problems with a slightly positive setup.
Thnx dude, helpful explanation :)
Old December 27, 2011, 06:38 AM
I edited my original post a bit.
My stuff for sale.
Mah Rig
Old December 27, 2011, 06:48 AM
Dude, Jus help me again in this lil prob, i have five fans opt. 1 in front bazel, two are at top, 1 at rear with cpu and 1 in bottom with psu. Now, according to this tell me the fans management, pz
Thanks
Old December 27, 2011, 06:49 AM
also if you are worried about dust and your case doesn't have filters there is a couple options!
1st one is the cheapo foam type filters that can be washed but build up fast and impeed airflow. The other is quite cheap and easy to do.
Purchase these kind or these kind it doesn't matter. Then purchase some screen door screen (its very cheap and some places bulk sell it)
cut and attach this stuff to either of the fan grills above. It will seriously catch a lot of the dust/hair and keep your case much cleaner.
My stuff for sale.
Mah Rig
Noctua NF-S12B airflow direction h0nam Air Cooling 5 November 8, 2010 03:18 PM
Smaller but good airflow case? bojangles Cases 12 November 11, 2008 05:45 PM
New case airflow tubabub New Builds 11 July 2, 2008 08:28 PM
Case Cooling and Airflow - How much does it matter CasheKicker Air Cooling 18 March 14, 2008 09:30 AM
