  #21 (permalink)
Old December 28, 2011, 11:21 PM
I try to filter the intakes... you said you were using a stock cooler for the cpu. So you could reverse the rear 120mm as an intake and then the top two are exhausts.
You can remove the filters if you want too... i dont like foam filters the other kind (screen type) are fine.
My stuff for sale.
Mah Rig
Noctua NF-S12B airflow direction h0nam Air Cooling 5 November 8, 2010 03:18 PM
Smaller but good airflow case? bojangles Cases 12 November 11, 2008 05:45 PM
New case airflow tubabub New Builds 11 July 2, 2008 08:28 PM
Case Cooling and Airflow - How much does it matter CasheKicker Air Cooling 18 March 14, 2008 09:30 AM
