Originally Posted by taimoorali007 Dude, Jus help me again in this lil prob, i have five fans opt. 1 in front bazel, two are at top, 1 at rear with cpu and 1 in bottom with psu. Now, according to this tell me the fans management, pz
Thanks |
top two fans out.
Rear fan out. (by cpu) cpu fan should be blowing straight out in the same direction if possible. if it doesn't you can reverse the rear fan to blow in.
every other fan blows in. (no side panel fan?)
If you have more fans blowing out than in... lower the speeds of the fans blowing out a bit and increase the fan speeds blowing in.
If you don't have fan control then you buy fans based on CFM. Slightly higher CFM in than out = positive pressure.
Here is a picture of when the rear fan SHOULD blow out.
