I started this trial in a previous thread What do your video cards temp while just playing singleplayer COD4..... ? and have decided to move it here for more testing. I have recently. last night, moved my system from my Antec 900 case into an old budget case in preparation to build my new rig. Immediately I have noticed a significant difference in my temps. I will start by posting my original data collected in my Antec 900 case last week. Next I will do a duplicate batch of tests identical to the first set only this time in my budget case. I will add the budget cast has virtually no airflow and no case fans what so ever. This will clearly show how important a good case with ample airflow is for your rig. Probably the most important factor when it comes to cooling over everything else like after market heatsinks. Not that they don't do wonders, but nothing like the temp changes I think you are going to see here. So my initial tests in detail with the identical system in the Antec 900 case are as follows: OK, after 4hrs of testing various setups of the GPU settings Well even though the drivers have the above warning everything appears to be working. SO after a few tests here are my readings. Note: I am running an Antec 900 case with 3 x 120mm Antec 3 speed fans in the front of my case blowing towards my MOBO and GPU, 1x120mm cooler master on my side panel blowing directly on the GPU, 1x120mm coolermaster exhausting out the back of the case, 1x240mm Antec 3 speed exhausting out the top of the case. I will play with these settings a bit but a very deep trial of all the different fan settings would take much to much time. Between each temperature I allowed appx, 15min between setting change to give the temps a chance to stabilize. All temps read with Rivatuner with -/+1 degree fluctuation, Ambient Room Temperature 20 Deg C, all load tests were done in COD 4, same settings with 1650x1080. Idle Readings @ Default settings all case fans on LOW Core Clk: 499.5 Mhz Mem Clk: 1188Mhz Core Tmp: 46.31 Deg C Amb Tmp: 37.06 Deg C Duty Cycle: 27% Fan Spd: 1751 rpm Volt Reg: 44 Deg C With the side panel fan disabled Core Tmp: 48.11 Deg C Amb Tmp: 39.34 Deg C Side Panel Removed Core Tmp: 49.27 Deg C Amb Tmp: 41.06 Deg C Interesting to note that removal of my side panel produced the highest temps at idle. EDIT: Turned off all Antec Case fans with the exception of read exhaust. Core Tmp: 52.88 Deg C Amb Tmp: 43.06 Deg C Goes to show case cooling makes a significant difference Bumping all 4 varible speed case fans to High: Core Tmp: 45.88 Deg C Amb Tmp: 35.06 Deg C Idle Temps with GPU Fan @ 60% case fans low Core: 38.55 Deg C Amb: 34.06 Deg C Case Fan speed adjustment brings both temps down a touch, about an additional 1 deg C For Giggles Idle Temps with GPU Fan @ 100% case fans low Core: 36.43 Deg C Amb: 34.06 Deg C Idle with GPU fan @ 100% Case Fans in my Antec 900 to the High settings keeping 100% Fan on GPU: Core: 35.52 Deg Amb: 33.06 Deg COD4 Readings @ Default settings Mission Select "Death From Above Note: in Game, Core Clk 621, Mem Clock 1800 Core Tmp: 85 Deg C Amb Tmp: 53 Deg C Duty Cycle: 36% Fan Spd: 2400 rpm Volt Reg: 57 Deg C Same as above with all case fans turned off with exception of rear exhaust. Core Tmp: 89.63 Deg C Amb Tmp: 62.06 Deg C COD4 Readings @ Fan @ 60% Mission Select "Death From Above Core Tmp: 70 Deg C Amb Tmp: 49 Deg C Duty Cycle: 59% Fan Spd: 3630 rpm Volt Reg: 57 Deg C COD4 Readings GPU Fan at @ 100% Mission Select "Death From Above Core Tmp: 62 Deg C Amb Tmp: 43 Deg C Duty Cycle: 100% Fan Spd: 5197 rpm Volt Reg: 57 Deg C COD4 Readings GPU Fan at @ 100% Mission Select "Death From Above with Case fans cranked to high Core Tmp: 56.25 Deg C Amb Tmp: 42.06 Deg C Note: The fan volume @ 60% is bearable but at 100% is sounds like my GPU is going to fly out of the case. I should pick up some after market cooling someday and compare these numbers. However it cant be ignored that the temps when all fans running at 100% and case fans on high the full load temps are almost identical to the Idle temps with no added cooling solutions. Quite impressive results. ![]() This was fun and educational!! The pictures in this thread are of the Antec 900 __________________
__________________ CasheKicker RIG #1 - AMD64 3500+ // Asus A8N-E // Radeon x1950xt // 2g Ram (4x512) // Basic Budget Case // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g RIG #2 - Intel E8400 // TRU-X 120 w noctua NF-P12 // Gigabyte GA-X38-DQ6 // nVidea 8800GTS 512 OC // 4g Ram Crucial Ballistic PC8500 1066Mhz (4x1g) // Antec 900 Gamers Case // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Samsung 226BW & 17"KDS CRT/ Logitec G-15 Last edited by CasheKicker; March 9, 2008 at 02:23 PM. |
I will be doing testing for the next several hours. Hopefully I will have some results and post them later this evening. I hope to have it complete by 8pm EST. Be sure to check back for the SHOCKING results.
__________________ CasheKicker RIG #1 - AMD64 3500+ // Asus A8N-E // Radeon x1950xt // 2g Ram (4x512) // Basic Budget Case // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g RIG #2 - Intel E8400 // TRU-X 120 w noctua NF-P12 // Gigabyte GA-X38-DQ6 // nVidea 8800GTS 512 OC // 4g Ram Crucial Ballistic PC8500 1066Mhz (4x1g) // Antec 900 Gamers Case // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Samsung 226BW & 17"KDS CRT/ Logitec G-15 |
| ATTENTION: All the following test results in this thread are invalid due to U.I.E. (user interface error). Disregard these results. I shall explain in detail after redoing all tests. Now in the BUDGET case. For ease of seeing the difference I have copy and pasted the original results in GREEN, the results for the BUDGET CASE can be seen in RED All temps read with Rivatuner with -/+1 degree fluctuation, Ambient Room Temperature 20 Deg C, all load tests were done in COD 4, same settings with 1650x1080. Idle Readings @ Default settings all case fans on LOW Core Clk: 499.5 Mhz Mem Clk: 1188Mhz Core Tmp: 46.31 Deg C 70.25 Amb Tmp: 37.06 Deg C 55.06 Duty Cycle: 27% Fan Spd: 1751 rpm Volt Reg: 44 Deg C 64.04 With the side panel fan disabled NOT APPLICABLE Side Panel Removed Core Tmp: 49.27 Deg C 66.25 Amb Tmp: 41.06 Deg C 52.04 Interesting to note that removal of my side panel produced the highest temps at idle in the Antec. Temps in the budget case actually reduced with the side panel off. EDIT: Turned off all Antec Case fans with the exception of read exhaust. Core Tmp: 52.88 Deg C Amb Tmp: 43.06 Deg C Goes to show case cooling makes a significant difference Even the design of the Antec case with no fans running proved to allow better airflow and better cooling than the budget case. Bumping all 4 varible speed case fans to High: NOT APPLICABLE Idle Temps with GPU Fan @ 60% case fans low Core: 38.55 Deg C 59.25 Amb: 34.06 Deg C 51.06 Case Fan speed adjustment brings both temps down a touch, about an additional 1 deg C For Giggles Idle Temps with GPU Fan @ 100% case fans low Core: 36.43 Deg C 54.13 Amb: 34.06 Deg C 47.06 Idle with GPU fan @ 100% Case Fans in my Antec 900 to the High settings keeping 100% Fan on GPU: N/A COD4 Readings @ Default settings Mission Select "Death From Above Note: in Game, Core Clk 621, Mem Clock 1800 Core Tmp: 85 Deg C Exceded 110 deg C after 5min test aborted Amb Tmp: 53 Deg C 76.06+ Duty Cycle: 36% Fan Spd: 2400 rpm Volt Reg: 57 Deg C 87+ Same as above with all case fans turned off with exception of rear exhaust. Core Tmp: 89.63 Deg C Amb Tmp: 62.06 Deg C COD4 Readings @ Fan @ 60% Mission Select "Death From Above Core Tmp: 70 Deg C Exceded 110 deg C after 5min test aborted Amb Tmp: 49 Deg C Duty Cycle: 59% Fan Spd: 3630 rpm Volt Reg: 57 Deg C COD4 Readings GPU Fan at @ 100% Mission Select "Death From Above Core Tmp: 62 Deg C Exceded 110 deg C after 5min test aborted Amb Tmp: 43 Deg C Duty Cycle: 100% Fan Spd: 5197 rpm Volt Reg: 57 Deg C COD4 Readings GPU Fan at @ 100% Mission Select "Death From Above with Case fans cranked to high N/A COD4 Readings GPU Fan at @ 100% Mission Select "Death From Above SIDE PANEL REMOVED I was able to complete the mission with the side panel removed, however the temps were still much higher than I am comfortable with. Core Temps reached 102 degC after only one mission, a duration of about 10mins The results are indisputable. The most important cooling solution anyone can purchase is a case that can provide adequate airflow to ensure every other solution can work efficiently. I was not even able to finish one single mission with my current setup even if I preset the GPU cooler to 100% fixed duty load cycle. In the antec case even when I was maxed out with all case fans turned off I was getting better temps than the "Budget Case" at idle. This certainly speaks volumes to me on the need for a GOOD case and lots of airflow. Now after changing all this hardware over to the budget case I feel the need to buy a new case or at least some case fans, as it is obvious that with this crap case I am running will only shorten the life of all my gear. Below is a photo of the culprit.
__________________ CasheKicker RIG #1 - AMD64 3500+ // Asus A8N-E // Radeon x1950xt // 2g Ram (4x512) // Basic Budget Case // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g RIG #2 - Intel E8400 // TRU-X 120 w noctua NF-P12 // Gigabyte GA-X38-DQ6 // nVidea 8800GTS 512 OC // 4g Ram Crucial Ballistic PC8500 1066Mhz (4x1g) // Antec 900 Gamers Case // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Samsung 226BW & 17"KDS CRT/ Logitec G-15 Last edited by CasheKicker; March 10, 2008 at 09:08 PM. |
As you can see by comparing the pictures from Test 1 to those of Test 2, the setup of the PCs were identical, the only factor that changed was the case and case fans. I was even using the same OCZ GameXstream 850w poser supply in both cases to ensure the power was stable and the same quality. I would have liked to do more extensive testing but based on my high temperatures I opted to stop before I hurt something. I feel the test was a success and a point has been shown. I can only imagine at this point how the CPU and other areas would also be affected.
__________________ CasheKicker RIG #1 - AMD64 3500+ // Asus A8N-E // Radeon x1950xt // 2g Ram (4x512) // Basic Budget Case // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g RIG #2 - Intel E8400 // TRU-X 120 w noctua NF-P12 // Gigabyte GA-X38-DQ6 // nVidea 8800GTS 512 OC // 4g Ram Crucial Ballistic PC8500 1066Mhz (4x1g) // Antec 900 Gamers Case // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Samsung 226BW & 17"KDS CRT/ Logitec G-15 Last edited by CasheKicker; March 9, 2008 at 02:30 PM. |
nice test. Can't find a lot of case test like that on the net.
__________________ asus p5kc, e6750 with thermalright ultra 120 extreme and antec tricool fan, evga 8800gt superclocked with thermaltake duorb, 2gb of crucial ballistix tracer and 2gb of mushkin hp, 1 seagate barracuda 250gb and 1 seagate barracuda 500gb |
I would enjoy that. Set up a nice set of standardized tests to show temps along with a smoke test to show airflow. That would be sweet now all I need is some cases to review.
wow the results were crazy. i seriously didnt think the temps would be that much higher. thanks for going through all that work and testing and posting your results
__________________ rampage formula , e6850 + ocz vendetta 2, mushkin xp 2x2g pc2-8500, xfx 8800gtx, zeus 750w psu, cm ammo 533, hdds, dvd writer, fans, cables etc... |
| Quote:
Anybody got any free fans they want to throw at me. I am not so sure I want to invest $$ in this case. I could probably get a new one for about the same as its going to cost me to mod it, ummm, well maybe not quite as cheap. But then again the mod sounds like much more fun.
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Lian Li PC-C32; Enough cooling/airflow? | Nate_The_Great | Cases | 3 | October 3, 2008 12:19 PM |
| Air Cooling - Case pressure | mattydies | Air Cooling | 4 | December 18, 2007 10:30 PM |
| dose the length of warranty really matter to u? | cmhyt | Video Cards | 7 | December 17, 2007 07:57 AM |
| Mid-tower water-cooling case? | 3.0charlie | Cases | 13 | October 31, 2007 07:07 PM |
| mesh for case cooling | magictorch | Water Cooling | 2 | September 18, 2007 05:12 PM |
