Old March 6, 2008, 11:03 AM
low351's Avatar
Default Scythe Ninja Rev B. for those considering it - lots of pics 56k warning!
I thought I'd post my pics of the Scythe Ninja Rev B. for those that are considering it. There are obviously in-depth reviews available but you can't see enough pics before you buy something, so here are mine.
My opinion for what it's worth: It's a large impressive looking cooler. Difficult to seat on an AM2 since it doesn't have a pulley style clip. Could use a lapping out of the box and seems to work better when you spread the TIM thin across the CPU rather than a bead of it. I get 36-37C idle and 59C under load with it in a well ventilated CM690 with an AMD X2 6400+ BE
And now for PICS!
The Beast in the Box
The Box side view with the clip options. AM2 Ready! (to shred your hands...)
The stock 120mm Scythe fan next to the HS
A closer look at the Fan and Heatsink
The underside. Be careful to clean off the residue from this sticker. and DON'T forget to remove it, lol. (I did remove it in case you are wondering.)
Here is a close up of the included Thermal Material, I don't know how good it is, I used AS5.
Intalled in a CoolerMaster 690 case, just enough headroom. It's tall!
And now a few vanity pics with a replacement Blue LED fan. CoolerMaster 1200rpm Blue LED.
Now to get on to that case window mod...
Old March 6, 2008, 12:04 PM
Babrbarossa's Avatar
Nice pics!
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Old March 6, 2008, 12:31 PM
yycraven's Avatar
so now is the fan on the back a exhaust or intake, just wondering cause I have same case and thinking of getting this cooler for my E6550.
did you lap your cooler.
Firefly: EVGA P55 Classified 200,X3440@4.2GHZ,NH-D14,Patriot Sector5 8GB ,WD 750GB Sata II,Sapphire HD4860 1GB DDR5,Thermaltake toughpower XT850W,Tech Station.
heatware
Old March 6, 2008, 01:36 PM
low351's Avatar
Thanks Barbarossa.
yycraven, The back fan is exhaust. I have the front fan in, the side fan in, and the one on the bottom next to the PSU is the stock Scythe fan blowing in. So with the Heatsync fan blowing back and the back fan exhausting I should have positive pressure in the case pushing out. I didn't lap the HS yet, the operative word is yet. You should have an easy time of it putting it in with the 775 push pins. Also there is an aluminum finned block near the bottom that you can see in the pic just before the one of the sticker, you want the fan to push through that ideally, I couldn't mount it that way since the fan would push up rather than line up with my back exhaust. I tried it though and didn't see a difference, but it would be optimal and easy on a 775 install.
Old March 7, 2008, 12:03 AM
yycraven's Avatar
Thanks for the info.
So have you notice and heat difference with this on.
whats the temp's compared to stock.
Oh yeah very nice set up with cable's and nice Blue LED's.
nice pics.
heatware
Old March 7, 2008, 08:57 AM
low351's Avatar
Unfortunately I don't have the stock temps since my 6400+ was a Black Edition which has no stock cooler. I did get a 2C drop when I changed the TIM from dot to spread method. I'd find it difficult to believe that this beast didn't do a much better job, in fact it has been argued that it has 12 heatpipes and not the modest 6 that scythe states, I guess they are counting the U as 1.
If you want to push and overclock though I haven't been that successful with this HS, I hit 62C and I didn't like it, I may be trying to push my Procs into watercooling territory though... I understand that 3.5Ghz is at the limit of the 6400+
Old March 7, 2008, 09:10 AM
yycraven's Avatar
well so far with my stock cooling Im doing 3.05GHz and full load its 53C. I figure if I get this for a HS I could go higher.
my goal is to get 3.6GHz on air on this chip.
we will see I guess.
heatware
Old March 7, 2008, 09:37 AM
ebdoradz's Avatar
ive always count heatpipe like that because its the same copper tube that made the U
6 U = 6 heatpipe
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 5112mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
ABIT KT7A-RAID / AMD Athlon XP 1800+ @ stock/ 2*256mb PC133/ Geforce 4 mx440 / 250W PSU / Maxtor 20GB
Old March 7, 2008, 06:18 PM
For those considering the Scythe Ninja Rev.B...it is an excellent cooler, but there are other choices with similar prices and same/better performance.
The Thermalright Ultima-90 is an excellent cooler, and is within a few dollars of the Ninja; but you need buy a fan for it. The Coolermaster GeminII is also a good choice if you want to cool the components around the CPU (eg. RAM, NB) as well. The TT120 is also a good choice now, as it's price has dropped a bit closer to the Ninja's. I also recall seeing some reviews saying that Scythe's own Infinity/Mugen(?) beats the Ninja, but it does cost a few dollars more...
I don't know what I'm trying to say or why I went through the effort to say what i said.....
Anyways, I have a Ninja and I think it's a great cooler...I need to lap it cuz my temps peak in the low 70s. Or maybe I could just get better fans...but I don't want to increase the noise...any recommendations?
Antec NSK 6500 w/ TriCool intake, S-Flex F exhaust
Corsair HX520
Gigabyte GA-965P-DS3 Rev1.0 @ 500FSB
Intel C2D E6300 @ 3.5ghz 1.45V
Arctic Cooling Freezer 7 Pro
Mushkin (996576) 2X1GB HP2-6400 @ 1000mhz 5-5-5-15 1.9V
eVGA 7600GT KO @ 630/880
Seagate 7200.10 320GB
Samsung SH-162
Samsung 205BW
Logitech Media Keyboard
Logitech MX518
Old March 7, 2008, 06:51 PM
thenewguy001's Avatar
Does this come with thermal compound? If so, what type is it?
Scythe Ninja Copper Review Comment Thread SKYMTL Air Cooling 16 June 14, 2010 10:55 PM
Scythe Ninja --> Scythe Ninja Copper vinister Member Reviews 12 February 27, 2008 11:19 AM
Scythe Ninja Plus Rev. B BALISTX Air Cooling 2 May 5, 2007 12:28 PM
