Old March 6, 2008, 06:21 AM
Default Thermalright Ultra 120 & 120 Extream, Difference?
So I want t pick up a Thermalright Ultra 120,
Question is which one to go with, which is bette and why?
The Ultra 120 0r the Ultra 120 Extream, gong by the name you would expect the Ultra 120 Extream to be the better cooling solution, however based on information found on Frostytech's Best 5 Heatsinks the Ultra 120 places 2nd and the Extream comes in # 4.
Does anyone have experience with both of these heatsinks that can voise a personal opinon on the 2. Is one larger than the other? ...
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
Old March 6, 2008, 06:53 AM
CMetaphor's Avatar
Quadfather
Ultra 120 = 4 heatpipes
Ultra 120 Extreme (aka TRUE) = 6 Heatpipes
Check out anandtech.com's cpu cooler reviews, the TRUE comes in as one the best of all time, so take that over the regular 120.
Old March 6, 2008, 07:00 AM
Mr. Cipher's Avatar
Well you're looking at 4 heatpipes (120) versus 6 (120 extreme). You can check out Ultimate CPU Cooling Solutions! USA for more information on their product line up.
From there I found that they are the same size (the dimensions of the ultra were L63.5 x W132 x H160.5 mm and the dimensions of the ultra extreme were L63.44 x W132 x H160.5 mm).
I can only speak of cooling with my ultra extreme, and with a 70% overclock on my system (its in my signature) it dropped about ~8-10 degrees under load.
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | Radeon HD 6870 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz |
BFG GTX 295 | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Old March 6, 2008, 07:43 AM
Good Info,
Thanks
CK
Old March 6, 2008, 09:38 AM
CMetaphor's Avatar
Quadfather
Cause I didn't say that in my post...
Old March 6, 2008, 11:16 AM
Mr. Cipher's Avatar
You posted as I was posting, hehe.
i7 Red
C2Q Blue
Antec 900 and a Thermalright Ultra 120 CasheKicker Air Cooling 22 March 30, 2008 05:02 PM
Can't get pins into X Bracket for Thermalright Ultra 90 Pylonman Troubleshooting 3 March 10, 2008 07:42 PM
Reviewer Tryouts: Thermalright Ultra-120 Extreme gof Member Reviews 7 November 23, 2007 11:17 PM
Request: Thermalright Ultra-120 specs S|nApSE Air Cooling 2 May 5, 2007 07:21 PM
A second look at the Thermalright Ultra 120 eXtreme Babrbarossa Reviews & Articles from the Web 2 May 4, 2007 06:23 PM
