Old November 28, 2011, 03:33 AM
Default Silverstone air penetrators any good for pull?
I know Silverstone air penetrators are really designed to be push fans (as in push into the case), but id rather all my LED fans matched, so would they be that bad as pull fans? I mean I know they will work, but will they work well? Or give a low pull performance?
Thanks
Old November 28, 2011, 12:06 PM
lowfat's Avatar
Is this for a radiator? Honestly I think the fan would do better pull. Just my opinion and guess though.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old November 28, 2011, 02:57 PM
coleo's Avatar
ive been using a 120mm as a pull on my h-50 since i assembled my rig. works fine and the directed airflow seems to me to be quieter than a regular ole 120 mm
Old November 28, 2011, 04:19 PM
I currently have an Antec 300, but plan on upgrading to a Corsair Obsidian 650D. In my Antec I would like 2 as push fans in the front, and 1 as a pull fan at the back. In the Corsair I would put 2 as pull fans on top, quite possibly for a radiator, and one on the back, probably as a pull. I would use the 200mm fan at the front as the push, and a 120mm on the bottom as push if I felt the airflow was insufficient. This would be another silverstone air penetrator.
Old November 28, 2011, 04:26 PM
dandelioneater's Avatar
I've always found that push is better than pull. Even with gelid wings at fullspeed, there really wasn't much air movement through my rad. pull < push < push/pull
Old November 28, 2011, 06:00 PM
Gelid Wings need to be shrouded for any kind of decent performance. The fan blade geometry makes for amazing static pressure, but the struts at the end leave a giant gap between the frame and the blades that result in a ton of recycled airflow.
To the OP, AP121/141's are great exhaust fans, in fact in my experience they perform better as a rear exhaust fan than as a front intake. (assuming there's a hard drive cage behind them) They also make great side/bottom fans. The terms push/pull are typically used for heatsink and radiator applications, not for the chassis.
Old November 28, 2011, 06:41 PM
Push pull for a chasis just makes more sense to me, though I spose you could say intake and outtake :P
Old November 29, 2011, 02:29 AM
rjbarker's Avatar
Intake / Exhaust
Firestrike Extreme: 21.452
MARK 11: 32.530
Silverstone FT02 and Silver Arrow make good buddies! Evochuck Overclocking, Tweaking and Benchmarking 3 October 13, 2011 10:23 PM
Silverstone Olympia OP750 - old but still good? Mook06 Power Supplies 6 December 2, 2010 07:23 PM
Before I Pull The Trigger curtispan Audio 0 March 13, 2010 04:37 PM
Everything look ok so I can pull the trigger? Strat6 New Builds 2 November 17, 2008 09:45 AM
think this can pull 2x 8800gt in sli? mmmstew Power Supplies 13 May 26, 2008 01:27 AM
