Old November 24, 2011, 06:20 PM
techman95's Avatar
Default which thermal paste?
so im looking for really the best thermal paste there is right now and have no idea. i know there is arctic silver 5 and noctua but is there one better?
Old November 24, 2011, 08:01 PM
Soultribunal's Avatar
If you don't mind how abrasive it is, IC7 is where it is at. At least for me, that stuff has served me well.
AC is still very good, as well as Zalman ZMSTG stuff.
-ST
Old November 24, 2011, 09:29 PM
techman95's Avatar
what do you mean abrasive as in itll take off the ink on my heatspreader? then no i really couldnt give a shite
and to be specific i want something that i can use on my CPU as well as my GPU. and ive heard good things about the noctua thermal paste but that zalman looks interesting as well.
Old November 24, 2011, 11:57 PM
supaflyx3's Avatar
yeah it'll remove all lettering on your CPU, but +1 for IC7.
Old November 25, 2011, 06:05 AM
Yeah couple of applications and switching around on my 1090T and the only way I can tell you what processor it is is through CPU-z
But damn does it work good.
I really liked the Zalman stuff after using their coolers and getting a whole tube with it. Works really well.
-ST
Old November 25, 2011, 10:05 AM
yycraven's Avatar
Well since it has Diamonds 7 Carat Thermal Compound yea it will take off the ink on cpu and remove the lettering.
But from what I hear its can drop temps from 5 to 10 degrees.
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Old November 25, 2011, 10:09 AM
techman95's Avatar
well guess im going on the hunt for some ic diamond 7 then just have to find a place that sells it around here, and im really surprised that newegg US doesn't carry it
Old November 25, 2011, 10:21 AM
Birk's Avatar
is this what you guys are talking about?
NCIX.com - Buy Antec Formula 7 Nano Diamond Thermal Compound Paste 4 Gram - Others - Formula 7 - in Canada
Old November 25, 2011, 10:45 AM
yycraven's Avatar
http://store1.hardwarecanucks.com/st...are%20Canucks/
heatware
Old November 25, 2011, 12:21 PM
Pabz0r545's Avatar
I just bought some Arctic MX-4 because I have to RMA my H100 and put my H60 back on. I hope the stuff is ok.
What thermal paste for my GPU? Polygon Video Cards 9 December 12, 2010 12:47 AM
Thermal Paste killerjay_47 Air Cooling 9 March 15, 2010 02:53 PM
Thermal Paste r0k0 Overclocking, Tweaking and Benchmarking 11 February 15, 2010 10:53 PM
Thermal Paste? Luckk Air Cooling 16 November 24, 2009 07:57 PM
Thermal Paste??? Salavat23 Water Cooling 6 December 27, 2007 05:43 PM
