Old March 3, 2008, 01:40 AM
Default Antec 900 and a Thermalright Ultra 120
Hi guys,
I plan on putting a TRU 120 on my new build. However I am concerned it may not fit in my Antec 900. I have a 120mm Fan on the side panel and am worried there is not enough room left to pop one of these suckers in.
Is there anyone currently using the same case, with a side panel fan, using a TRU 120.
Cheers
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
Old March 3, 2008, 02:13 AM
will have to remove fan.
ultra 120 and tuniq have like 1mm of gap before the panel.
Old March 3, 2008, 05:14 AM
Well perhaps a small mod to place the fan on the outsid eof the side panel is in order. My recent tests of GPU temps shows a marked improvement with the side fan onboard.
What do your video cards temp while just playing singleplayer COD4..... ?
Old March 3, 2008, 05:35 AM
Mr. Cipher's Avatar
Of course it will!
I have the side case fan and the TRU fits fine. You have to change the orientation however, so the longer side of the TRU faces up (e.g. if there was a fan on the TRU, it would be pointing either to the bottom/top of the case, rather than front/back).
Cooling was not hampered in my system (load 53/54 before and after), and my GPU still gets some nice, fresh air.
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | BFG GTX 295 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Intel E1xxx & E2xxx OC Thread
Old March 3, 2008, 06:52 AM
Well pointing to the top would not be a bad thing at all with the 900 case setup. The 240mm fan at the top of the case is there to exhaust out of the case anyway. I see this orientation as a benifit.
Thanks for the info.
CK
Old March 3, 2008, 06:55 AM
I am thinking of doing a smoke style test on the case to see the actual airflow under different configurations. That could be interesting. Has anyone here ever experimented with that style of testing?
Old March 3, 2008, 08:17 AM
Mr. Cipher's Avatar
I would be really interested in seeing these results. I'm curious to see how the side fan affects the case airflow, when it is set on either intake/exhaust. If you do go through with it, let me know what you find out.
i7 Red
C2Q Blue
Old March 3, 2008, 01:49 PM
I most cetainly will. Think it will be a fun project. However, I do not expect to have the time to do it for awhile. Lots of other things to do at the moment.
If you are interested to see the cooling results on the GPU with the side fan blowing on it read my recent test I did here What do your video cards temp while just playing singleplayer COD4..... ?
Old March 3, 2008, 03:07 PM
I have two 120mm fans attached to my TRUE 120 in a push/pull config, so that all the air is pushed out the top through the 240mm fan. I was going to mount it in the other direction so that the air would go through the back exhaust fan, but my NB was in the way.
I can tell you that with my config, I'm not able to fit a 120mm fan on the side window. However, I did manage to fit a 92mm fan - it holds together very nicely with a couple of zip ties and only one of the four "raised mounts" through the fan.
Old March 12, 2008, 02:52 PM
dukelod's Avatar
I put the 120 ultra extreme in my 900 this weekend, it was a very tight fit. Also replaces the tim on the mosfets and north & south bridge while I had it out, and reversed my hdd. To keep a 120mm fan in the side window, I cut out a new window and lowered the fan.
Intel Core i7 930
Thermalright Ultra 120 Extreme Black Ultra Kaze 3000rpm
EVGA X58 3Way SLI A1
Corsair XMs3 6GB DDR3 1600
Windows 7 Ultimate 64bit
Antec Truepower Quattro 1200 OC Version
XFX GTX295
XFX GTX295
Coolermaster HAF 932
Logitech G15 Keyboard
Logitech G5 Mouse
X-Fi XtemeGamer
Can't get pins into X Bracket for Thermalright Ultra 90 Pylonman Troubleshooting 3 March 10, 2008 07:42 PM
Thermalright Ultra 120 & 120 Extream, Difference? CasheKicker Air Cooling 5 March 6, 2008 10:16 AM
Reviewer Tryouts: Thermalright Ultra-120 Extreme gof Member Reviews 7 November 23, 2007 10:17 PM
Request: Thermalright Ultra-120 specs S|nApSE Air Cooling 2 May 5, 2007 07:21 PM
A second look at the Thermalright Ultra 120 eXtreme Babrbarossa Reviews & Articles from the Web 2 May 4, 2007 06:23 PM
