Old November 20, 2011, 01:07 AM
Default Query on 3 pin fans.
Hello guys,
I'm planning on adding some case fans for my gaming rig...
procy : i5 2500K
mobo : Asus P8Z68-V
RAM : RipjawsX 8GB
GPU : 9800GT
PSU : Silent pro M600
Case : NZXT Gamma
My motherboard has 3*3 pin fan headers & 1*4 pin fan header(excluding 2*CPU fan headers).
My question is,
If i connect 3 fans(which has 3 pin headers & 4 pin molex) to the motherboard's 3 pin fan headers, will i be able to control the fan speed or at least the mobo itself regulates the fan with respect to the temperatures?
Old November 20, 2011, 01:37 AM
Avenger212's Avatar
I am not sure about the fans being controlled through bios or third party software, But I can tell you this the motherboard will automatically adjust the fan speed to correspond with the temperature inside the case. Also if you don't already know (sorry if you do already know) you can always connect your fans directly to the power supply which will run at full speed.
Old November 20, 2011, 01:40 AM
Yeah, i know that.. I'm concerned about the noise..
Avenger212's Avatar
A loud and annoying! well for me it is (for the molex) but for the mobo just fine
Old November 20, 2011, 08:19 AM
Arinoth's Avatar
No you cannot, unless you use a third party fan controller, you cannot speed control fans who only have 3 pins from your motherboard. Those 3 pins are 12V, GND, and Speed sense/RPM reader. The fourth pin which isn't included is the PWM pin, which is the pin that allows the motherboard to control the speed of the fan. Third party fan controllers can change the speed of 3 pin fans because they down volt the fan, causing it to run slower.
Here I am: here I remain
Old November 20, 2011, 09:15 AM
Thanks for the explanation but i'm aware of it.
What exactly is the benefit of motherboard 3 pin fan headers over the 4 pin molex connectors ??
Old November 20, 2011, 09:21 AM
Arinoth's Avatar
None really, actually it can be a downfall as the 3 pin fan headers do not supply typically as much current to the fans as per the 4 pin molex connectors. This means your fans will typically run a bit faster (or always at their full speed setting) if connected to molex rather then 3 pin fan header.
Old November 20, 2011, 09:25 AM
stoanee's Avatar
A lot less wiring clutter.
heatware
Old November 20, 2011, 09:26 AM
Check your BIOS settings to see if your motherboard supports fan speed control of non PWM fans. (typically fan control options Voltage versus PWM) Most Gigabyte boards and a lot of Asus/MSI boards offer this feature.
If you want the motherboard to regulate the speeds based on temperatures, you can use something like the Sunbeam Rheosmart controllers. Sunbeamtech Rheosmart PCI Fan Controller There are also a lot of fan controllers that feature temperature sensors that can be used to regulate fan speed.
Old November 20, 2011, 10:57 AM
Galcobar's Avatar
ASUS has AI Suite II included with its P8 Cougar Point motherboards, which allows for fully adjustable temperature-based profiles for the chassis and CPU fans via PWM and voltage control. They can only be controlled in those two groups, however, and not individually. The PWR fan headers cannot be controlled. The details of how many fans can be controlled varies depending upon the model.
http://images.anandtech.com/doci/433...an%20Xpert.png
According to ASUS forum mods, the headers can supply a maximum of 1 amp at 12V.
XFX HD 5870 Query rjbarker Video Cards 20 April 16, 2010 06:50 PM
External HD Query rjbarker Storage 3 February 4, 2010 03:55 PM
Network Switch(es) Query Shftup Storage 7 January 15, 2010 05:23 PM
QX9650 Query.. rjbarker CPU's and Motherboards 11 December 6, 2008 07:29 AM
TJ09 Fan Arrangement Query rjbarker Air Cooling 3 November 12, 2008 07:24 PM
