Old October 30, 2011, 08:49 PM
Default Venomous X or H100?
Basically thinking of doing a bit of upgrading together with some CPU overclocking.
Stock coolers are out of the questions and well I've been looking at either the Venomous X or the Corsair H100.
Which would be best in terms of value for money, sound from fan etc.
(PS will probs wait for Ivy core but may as well put this out there now.)
Thanks in advance,
Drumroll :)
Old October 30, 2011, 10:12 PM
Thanks in advance,
Drumroll :)
H100 rad can be tricky to mount depending on your case we need to know what your case and other specs are first. Also if you don't have low profile ram you might not be able to get your venomous x on either.
Old October 30, 2011, 10:37 PM
Kay atm i'm looking at the 500R case so mounting it shouldn't be a problem at all.
Well this are the specs atm but possible changes in future.
CPU Intel Core i7 2600K
Motherboard ASRock Z68 Fatal1ty Professional Gen3
Graphics MSI GTX 570 Twin Frozr III PE/OC
Optical Drive LG Blu-Ray Combo
HDD1 Seagate Barracuda 1TB ST31000524AS
HDD2 Seagate Barracuda 1TB ST31000524AS
Case Corsair Carbide 500R Case - White
Power Supply CoolerMaster Silent Pro Gold 1000W
CPU Cooler Thermalright Venomous X Silent CPU Cooler OR Corsair H100
RAM Corsair CML16GX3M4A1600C9 16GB (4x4GB) Vengeance DDR3
SSD Corsair Force Series 3 120GB SSD
Old October 30, 2011, 10:38 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Why not get the H80 instead of those two? Great temps, easy to install (something the H100 aint) and all round a great cooler. Unless you plan for insane OC's it will be a great fit. YMMV but thats what I plan on doing for my socket 2011 build. :)
Old October 30, 2011, 10:41 PM
Yeah I was actually looking at that as well as the Antec 620 or 920 as well but then looking at some reviews the Venomous X actually outperformed them and it costs lesser or smth but I'm looking at the H100 as it could potentially out perform the Venomous X? but i'm not sure thus the thread
:D if you have any reviews to share link plox :3
Old October 31, 2011, 12:32 AM
AkG's Avatar
AkG AkG is offline
Sure...here you go:
Corsair Hydro Series H80 Liquid CPU Cooler Review
Corsair Hydro Series H100 Liquid CPU Cooler Review
The only way a ven x will beat a H80 is if the case you are using it in has GREAT air flow...and even then I have serious doubts.
Old October 31, 2011, 05:30 AM
After looking at it a little, I've decided to either go for the H80 or H100
Thermalright Venomous X CPU Cooler Review
Looking at the results and comparing them as well as price etc, its roughly 15 dollars-ish price difference between the H80 and the Venomous X in Australia
and the H100 is approximately 20 dollars more then the H80. Would it be worth the extra 20 dollars for the 6 degrees difference between the H80 and H100?
Old October 31, 2011, 07:52 AM
GT7R's Avatar
H80 all the way. Don't forget that when you're running the H100 as an exhaust, all the hot air from the video card and other components will go directly into the radiator, so the temps won't be that better than a H80.
Old November 17, 2011, 05:08 AM
I thought the Silver Arrow is the new king from Thermalright...?
Old January 2, 2012, 02:04 PM
why don't u go silver arrow?
Corsair H100 or TT Big Water 760 Plus? siegfx Water Cooling 9 October 26, 2011 06:42 PM
Recall On Corsair H100 keto Water Cooling 5 October 4, 2011 07:50 AM
Gentle Typhoon AP-15 or AP-29 or other for H100 ipaine Water Cooling 34 September 8, 2011 04:48 PM
H80 or H100 Reviews? PerryC Water Cooling 40 August 21, 2011 07:57 AM
