Originally Posted by JJThomp Depending on the cooler width i can only have 1 fan however because of the case layout the 180mm case fan blows through the CPU cooler so it really only needs a pull fan. I will be overclocking, I was hoping for something a tad better than the hyper 212+ (hence why I was looking at the evo and V6). Even if it is only marginally better I have this budget and don't mind using it all.
Anyone know how these self contained water coolers work in my case? I looked it up but case availability is slim and I guess not many people have tried it. Which brings me to another option should I just save up for an H80. |
Just looking at a few pictures of your case, it looks like you should have enough room to mount a self-contained water cooler. If you stretch your budget a bit, you might be able to afford a Corsair H60. An H80 would be quite a bit over your budget though, but would be a better performer with the bigger radiator and push/pull fans.
Personally, if it were me, I think I'd get one of the self-contained water coolers...namely the H80. It wouldn't take up so much space and would leave you room for things like tall RAM heat spreaders, etc...
