Old October 27, 2011, 06:46 AM
great_big_abyss's Avatar
Default I need a new cooler. AMD AM3+ socket
Hi All:
Motherboard: M5A97 (AM3+ socket)
Processer: AMD Phenom II 965
I'll be putting an FX 8150 in when it arrives next month, so any cooler should fit both CPU's.
My system is overheating with the stock cooler while playing BF3 and keeps on crashing. I would like to put in a new cooler to:
A) keep things cooler and prevent BSOD/random restarts
B) quiet things down (the stock cooler is LOUD)
I am NOT overclocking, and would like to spend no more than $60 CAD.
Any ideas?
Old October 27, 2011, 07:17 AM
Soultribunal's Avatar
NCIX.com - Buy Zalman CNPS9900A LED CPU Cooler 120MM Blue LED Fan LGA1366 1156 1155 775 AM3 AM2 754 939 940 W/STG2 - ZALMAN TECH - CNPS9900A LED - in Canada
This cooler has worked for me flawlessly on my X4, X6 builds. Used it 5 times, its quiet even at full speed and it does an amazing job of cooling the CPU.
NCIX.com - Buy Antec Kuhler H20 620 Liquid CPU Cooling System LGA775/1155/1156/1366 AM2/AM3/AM3/FM1 + 2000RPM - Antec - KUHLER H20620 - in Canada
If you have a little more cash beyond $60 to spend after taxes I would suggest the cooler above.
ST
www.realhardwarereviews.com
Old October 27, 2011, 07:36 AM
uwish's Avatar
Venomous X RT..around $60 at canadadirect.ca I am running it with my 1090T with an ASUS M5A99X (AMD 3+) board.
AMD 1090T @ 4Ghz
Thermalright Venomous X RT cooler
AMD M5A99X EVO MB
4GB DDR3 RAM
XFX Radeon 6870
Coolermaster Haf X case
>3 TB storage
dual Samsung 22" widescreens
Old October 27, 2011, 11:41 AM
Well, I picked up a Xigmatek Gaia SD1283 cooler from CBIT at lunch. I also grabbed another 120mm fan to supplement the existing rear fan in my case. I'll set it to exhaust out through the top of the case.
I guess I'll have some fun disassembling my computer so I can install this thing.
Old October 27, 2011, 02:23 PM
dandelioneater's Avatar
coolermaster hyper 212+ $30 or less.
Old October 27, 2011, 03:04 PM
CoolHandL's Avatar
+1 for the Coolermaster Hyper 212+, it can be pricematched for 20$ sometimes
Link: NCIX.com - Buy Coolermaster Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA1155 LGA1156 120MM - COOLERMASTER - RR-B10-212P-G1 - in Canada
I have a few of them, use them on a lot of builds. I now use a Noctua NH-d14 its a monster, i bought it on sale for $59.99 (Rae sale price)
Old October 27, 2011, 03:38 PM
LightningJR's Avatar
I agree. CM Hyper 212+ is cheap and gets the job done. Even if you want to OC a little in the future it's still possible with the CM.
Old October 27, 2011, 11:21 PM
Well, I put the Xigmatek in, as well as my new case fan. So far so good. I ran a few benchmarks, including 3D Mark 11, Unigine Heaven and a few hours of BF3. CPU temps don't rise above 41C under load. What a difference from having my computer crash because the cooling system couldn't handle BF3 or even the CPU test in 3D Mark.
My next question now: I'd like install a fan at the top vent on my case (Thermaltake V4). However, I have clearence issues. A 120x120x25 fan contacts the Ram and the small MB power cord. Is there such a thing as a low profile fan? Say, no deeper than 12.5mm?
Old October 28, 2011, 06:41 AM
NCIX.com - Buy Scythe KAZE-JYUNI Slip Stream Slim 120MM 12MM Cooling Fan 1600RPM 28.8DB 38CFM - Scythe - SY1212SL12M - in Canada
This one will do the trick. 12mm.
ST
Old October 28, 2011, 06:47 AM
Right on, Thanks. That is exactly what I'm looking for.
1156 Evga p55 FTW Socket Burn (Foxconn Socket) Myst88 CPU's and Motherboards 9 May 8, 2011 02:53 AM
Cooler for Socket 1156 I5... Ryoohki Air Cooling 3 October 3, 2009 01:40 AM
[WTB] Socket LGA775 cooler - ASAP! ImmaPC Buy/Sell & Trade 12 August 15, 2009 11:32 AM
AM3 socket v. OCZ Vendetta 2 Cooler: Can It Be Done? spAzz77 CPU's and Motherboards 5 May 5, 2009 02:01 AM
[WTB] CPU cooler for socket AM2+/AM2 yamawho Buy/Sell & Trade 2 February 22, 2009 07:51 AM
