Old October 22, 2011, 08:49 AM
Default Help with fan size
Will this fan fit on this motherboard with out covering any slots. If it dosnt what cooler do you reccommend. This is my first Computer build so I dont want to risk useing water cooling.
Motherboard: Intel® Desktop Board DX58SO2
Fan: Thermaltake CLP0564 Frio Dual 120mm Universal CPU Cooler - LGA1366, LGA1156, LGA775, AM3, AM2+, AM2. Received The Overclockers Tech Gold Award at TigerDirect.com
or
Thermaltake CLP0575 Frio OCK CPU Cooler - 2x 130mm Fans, Intel Socket LGA1366, 1155, 1156, AMD Socket AM2, AM2+, AM3, 6x 6mm Heat Pipes at TigerDirect.com
which ever fits better
Ram: Corsair CMZ12GX3M3A1600C9 Vengeance 12GB DDR3 RAM - PC12800, 1600MHz, 3x4096MB, Non-ECC, Unbuffered at TigerDirect.com
Old October 22, 2011, 11:08 AM
dandelioneater's Avatar
You should check out getting a coolermaster H212+ cooler. it is half the price of the thermaltake and performs probably just as well if not better. i have mine with 2 coolermaster blue led 2000 rpm fans at 75% speed and it is super quiet .
H212+ cooler
fans
Old October 22, 2011, 02:50 PM
so will this h212+ fit in a HAF 932 and not cover any slots?
Old October 22, 2011, 04:26 PM
supaflyx3's Avatar
Yes. They are both coolermaster products, so I'm sure they've tested to make sure everythign works together, but from experience i can say it does. You'll have to install the ram first though.
Old October 22, 2011, 04:57 PM
thanks you guys really helped :D
Old October 25, 2011, 02:07 PM
uwish's Avatar
I have 4 CM 200 mm case fans, and my video card cooling fan which is 100mm is significantly louder than all the case fans combined. I can highly recommend CM fans, they are quiet and generally move a considerable amount of air.
AMD 1090T @ 4Ghz
Thermalright Venomous X RT cooler
AMD M5A99X EVO MB
4GB DDR3 RAM
XFX Radeon 6870
Coolermaster Haf X case
>3 TB storage
dual Samsung 22" widescreens
Gtx 275 vs gtx 570 size coalminer071 Video Cards 8 October 14, 2011 11:30 AM
6950 size techman95 Video Cards 14 February 2, 2011 11:56 AM
Rad Size homer98 Water Cooling 11 December 10, 2010 08:33 AM
aluminum which size? CTA Cases 6 October 20, 2010 11:33 PM
What Stripe Size to Use? catnhat Storage 2 August 25, 2010 10:19 AM
