Old October 18, 2011, 09:09 PM
Default Linus, I need help picking a HSF that fits with 4x4gb Corsair Vengeance ram!
Hey Linus!
Big fan of your show! I saw on your profile that we can come here to ask you questions.
Well.. here's the issue.
I have 4x4gb Corsair Vengeance ram and they have really really tall heat spreaders =/
I was wondering what heatsink fits with this RAM. I had an i3 2100 and I just bought an i5 2500k. I need a good HS that will fit nicely with these DIMMs but it seems most are way too big and cover the first slot.
Can you gimme some advice on cooling for my new CPU without blocking the RAM (its height... my god)
Old October 18, 2011, 10:24 PM
NI3 NI3 is offline
What motherboard is it? For a 99% guaranteed fit, one of the self contained liquid cooling units will work (H50 - 100).
Old October 23, 2011, 12:52 PM
francisw19's Avatar
Yup...agreed with NI3. The only way your doing this is with the pre-built water coolers. Otherwise, you'll just be using the stock cooler. I can't think of any after-market HSF that will fit. :/
Old November 21, 2011, 07:34 AM
Lsv's Avatar
Lsv Lsv is offline
Wait for the new Noctua's they featured at CES 2011.
i7 920 (no oc) w/ Noctua NH-D14
Asus P6T
Asus 6950 DC II 2gb
12gb G.Skill Ripjaws 1600mhz
Intel X-25M 80gb Gen2
2x WD Caviar Green 1TB 64m cache
2x WD Caviar Green 2TB 64m cache
Native Instruments Komplete Audio 6
Seasonic X-660
Fractal Design R3 + 4x Noctua S12B 120mm
Old December 12, 2011, 02:43 PM
great_big_abyss's Avatar
I think that most coolers are tall enough to fit over top of the first stick of RAM. I have a Xigmatek Gaia SD1283 that fits, and I'm sure that a common cooler like the CoolerMaster 212 is the same. The only caveat is that I have to remove the cooler before i can remove/install RAM.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old December 12, 2011, 03:17 PM
or you can do what my friend did, take a dremel and cut off the fins
Old December 12, 2011, 03:56 PM
duno whats sadder...the fact that people do this instead of just getting a cheaper heatsink that would actually fit and perform better due to not being gimped or that this is only the 2nd worst heatsink mod ive ever heard of (worst was some idiot who chopped off the top of all the heatpipes so he could close the side panel).
Old December 12, 2011, 08:58 PM
Chill bro, my bud had his ram stock speeds stock voltage, so it doesnt run hot esp with the fan on his cpu heatsink cooling it. The vengeance ram with the low profile heatsink is the same thing. unless the cpu is watercooled, then the ram can get warm at a voltage like 1.65v because theres more airflow going past the heatspreaders. I saw the post of the guy cutting off the ends of the heatpipes and THAT would really affect the performance because the heat transfer of heatpipes depends on the juice inside them
Old December 13, 2011, 09:38 AM
Slaughter's Avatar
I believe he was referring to the fins on the top of the ram.. Not the CPU heatsink. :)
Those tall modules can be quite hard to fit with most aftermarket coolers. I haven't found one that works personally, but I would look at the all in one water cooling solutions as NI3 suggested.
Old December 13, 2011, 10:23 AM
Adzsask's Avatar
Closed water loop, For a little i3 I would toss on a coolermaster hyper 212+ .
Corsair Vengeance 1300 Retro. Audio 2 October 4, 2011 10:20 AM
Corsair Vengeance Gaming Peripherals ilya Reviews & Articles from the Web 11 September 26, 2011 07:11 PM
Corsair Dominator (1.65V) or Vengeance LP (1.5V) 1600MHz 9-9-9-24 futures RAM 9 September 7, 2011 09:48 PM
Anyone getting reviewed speeds on Corsair Vengeance? BlueByte RAM 0 February 8, 2011 06:04 AM
