Old December 13, 2011, 10:26 AM
Birk's Avatar
i use the same ram as you, i think the NH-D14 will fit but I'm not sure I haven't desided yet which cooler to use between that or the H100
Old December 13, 2011, 03:29 PM
NH-D14 will not fit
I recommend the NZXT Havik 140, it doesn't go over the first slot so you are clear with your memory. it also has 2x 140mm fans so it is pretty quiet
Old December 24, 2011, 12:41 PM
TokeR's Avatar
I would go with one of the Corsair closed water cooling kits. These days if you're not on a really tight budget but you don't want all the hassle and expense of a proper water cooling loop then I don't know why you wouldn't choose one of these kits companies like corsair are offering.
You can get a H60 from NCIX for $75 and there are better ones but obviously they cost more. But the way these are designed there will be absolutely no issues with your RAM's clearance.
Corsair Vengeance 1300 Retro. Audio 2 October 4, 2011 10:20 AM
Corsair Vengeance Gaming Peripherals ilya Reviews & Articles from the Web 11 September 26, 2011 07:11 PM
Corsair Dominator (1.65V) or Vengeance LP (1.5V) 1600MHz 9-9-9-24 futures RAM 9 September 7, 2011 09:48 PM
Anyone getting reviewed speeds on Corsair Vengeance? BlueByte RAM 0 February 8, 2011 06:04 AM
